Introdução
The battery is a critical component that keeps your device powered. It supplies energy to all parts of the laptop and must hold a charge long enough to make the device portable.
If your laptop can’t hold a charge or must remain plugged in to stay on, the battery is likely the cause.
This guide shows how to replace the battery in a Lenovo IdeaPad L340-15API.
Before you begin, power off the laptop and disconnect the charging adapter and any external peripherals.
O que você precisa
Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
