Ir para o conteúdo principal
HyperX Alloy Origins Backplate Replacement
O que você precisa
  1. HyperX Alloy Origins Backplate Replacement, Toggle Indicator Tab: passo 1, imagem 1 %32
    • Locate the toggle indicator tab on the top right corner of the keyboard.
    Pergunte ao FixBot
    Comentar
  2. HyperX Alloy Origins Backplate Replacement: passo 2, imagem 1 %32 HyperX Alloy Origins Backplate Replacement: passo 2, imagem 2 %32
    • Insert the metal spudger or some other separating instrument into the right crevasse between the tab and the keyboard.
    • Lift up gently on the tab, while holding the left side of the tab down.
    • The tab can spring upwards upon removal. Eye protection is recommended during this step.
    Pergunte ao FixBot
    Comentar
  3. HyperX Alloy Origins Backplate Replacement, Backplate: passo 3, imagem 1 %32 HyperX Alloy Origins Backplate Replacement, Backplate: passo 3, imagem 2 %32
    • Flip the keyboard over so that the backplate is facing you.
    Pergunte ao FixBot
    Comentar
  4. HyperX Alloy Origins Backplate Replacement: passo 4, imagem 1 %32 HyperX Alloy Origins Backplate Replacement: passo 4, imagem 2 %32 HyperX Alloy Origins Backplate Replacement: passo 4, imagem 3 %32
    • Remove the rubber feet on the four corners of the backplate.
    • When reassembling, use an adhesive to reattach the feet. A silicone rubber adhesive is recommended.
    Pergunte ao FixBot
    Comentar
  5. HyperX Alloy Origins Backplate Replacement: passo 5, imagem 1 %32 HyperX Alloy Origins Backplate Replacement: passo 5, imagem 2 %32 HyperX Alloy Origins Backplate Replacement: passo 5, imagem 3 %32
    • Remove the specified keycaps as depicted in the image.
    Pergunte ao FixBot
    Comentar
  6. HyperX Alloy Origins Backplate Replacement: passo 6, imagem 1 %32 HyperX Alloy Origins Backplate Replacement: passo 6, imagem 2 %32 HyperX Alloy Origins Backplate Replacement: passo 6, imagem 3 %32
    • Remove all Philips #0 screws from the new openings created after removing the rubber feet and plastic tab.
    Pergunte ao FixBot
    Comentar
  7. HyperX Alloy Origins Backplate Replacement: passo 7, imagem 1 %32 HyperX Alloy Origins Backplate Replacement: passo 7, imagem 2 %32 HyperX Alloy Origins Backplate Replacement: passo 7, imagem 3 %32
    • Separate the backplate from the keyboard using your hands.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Mario Ricci
Membro desde: 10/25/22
294 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 5-2, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 5-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G2
5 Membros
Autoria de 15 guias
1Comentário do guia
my plate was scratched due to being separated using a metal screw driver, do you have any recommended paints to go over the scratched areas with?
Damian Burton - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 45
Ao todo: 1,999
