Ir para o conteúdo principal
Huawei P20 LCD Screen & Digitizer Replacement
O que você precisa
  1. Huawei P20 LCD Screen & Digitizer Replacement, Rear Glass: passo 1, imagem 1 %32
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
    Pergunte ao FixBot
    Comentar
  2. Huawei P20 LCD Screen & Digitizer Replacement: passo 2, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 2, imagem 2 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 2, imagem 3 %32
    • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
    Pergunte ao FixBot
    Comentar
  3. Huawei P20 LCD Screen & Digitizer Replacement: passo 3, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 3, imagem 2 %32
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    Pergunte ao FixBot
    Comentar
  4. Huawei P20 LCD Screen & Digitizer Replacement: passo 4, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 4, imagem 2 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 4, imagem 3 %32
    • Insert a third opening pick at the bottom left corner.
    • In the next few steps whilst cutting around the power button and rear camera make sure you only use the tip of the opening pick to avoid cutting the cable, smearing the lens or damaging the camera.
    • Start to slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
    Pergunte ao FixBot
    Comentar
  5. Huawei P20 LCD Screen & Digitizer Replacement: passo 5, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 5, imagem 2 %32
    • If the adhesive becomes hard to cut it most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the back cover.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Pergunte ao FixBot
    Comentar
  6. Huawei P20 LCD Screen & Digitizer Replacement: passo 6, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 6, imagem 2 %32
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
    Pergunte ao FixBot
    Comentar
  7. Huawei P20 LCD Screen & Digitizer Replacement: passo 7, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 7, imagem 2 %32
    • Lift and remove the back cover.
    • Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    Pergunte ao FixBot
    Comentar
  8. Huawei P20 LCD Screen & Digitizer Replacement, Motherboard Cover with NFC: passo 8, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement, Motherboard Cover with NFC: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to peel the black tape next to the rear camera off the motherboard cover.
    Pergunte ao FixBot
    Comentar
  9. Huawei P20 LCD Screen & Digitizer Replacement: passo 9, imagem 1 %32
    • Remove the eight Phillips #00 screws (3.1 mm length).
    Pergunte ao FixBot
    Comentar
  10. Huawei P20 LCD Screen & Digitizer Replacement: passo 10, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 10, imagem 2 %32
    • Use a pair of tweezers to peel the black foil at the bottom end of the phone off the loudspeaker.
    Pergunte ao FixBot
    Comentar
  11. Huawei P20 LCD Screen & Digitizer Replacement: passo 11, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 11, imagem 2 %32
    • Slide an opening pick under the right side of the motherboard cover.
    • Rotate the opening pick slightly to pry up the motherboard cover.
    Pergunte ao FixBot
    Comentar
  12. Huawei P20 LCD Screen & Digitizer Replacement: passo 12, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 12, imagem 2 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 12, imagem 3 %32
    • Remove the motherboard cover with NFC.
    Pergunte ao FixBot
    Comentar
  13. Huawei P20 LCD Screen & Digitizer Replacement, Battery Disconnect: passo 13, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement, Battery Disconnect: passo 13, imagem 2 %32
    • Use a spudger to pry up and disconnect the battery connector.
    Pergunte ao FixBot
    Comentar
  14. Huawei P20 LCD Screen & Digitizer Replacement, Daughterboard Cover: passo 14, imagem 1 %32
    • Remove the three Phillips #00 screws (3.2 mm length).
    Pergunte ao FixBot
    Comentar
  15. Huawei P20 LCD Screen & Digitizer Replacement: passo 15, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 15, imagem 2 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 15, imagem 3 %32
    • Use a pair of tweezers to remove the daughterboard cover.
    Pergunte ao FixBot
    Comentar
  16. Huawei P20 LCD Screen & Digitizer Replacement, Charging Board with Main Flex: passo 16, imagem 1 %32
    • Remove the two Phillips #00 screws (3.2 mm length).
    Pergunte ao FixBot
    Comentar
  17. Huawei P20 LCD Screen & Digitizer Replacement: passo 17, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 17, imagem 2 %32
    • Use a spudger to pry up and disconnect the main daughterboard connector from the daughterboard.
    Pergunte ao FixBot
    Comentar
  18. Huawei P20 LCD Screen & Digitizer Replacement: passo 18, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 18, imagem 2 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 18, imagem 3 %32
    • Use a pair of tweezers to pry up and disconnect the connector of the white coax cable from the motherboard.
    • Unroute the white coax cable from the metal clips on the daughterboard and fold it to the side.
    Pergunte ao FixBot
    Comentar
  19. Huawei P20 LCD Screen & Digitizer Replacement: passo 19, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 19, imagem 2 %32
    • Use a spudger to disconnect the main flex cable connector from the motherboard.
    Pergunte ao FixBot
    Comentar
  20. Huawei P20 LCD Screen & Digitizer Replacement: passo 20, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 20, imagem 2 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 20, imagem 3 %32
    • Remove the charging port and main flex cable by lifting it upwards and then pulling it in the direction of the motherboard.
    Pergunte ao FixBot
    Comentar
  21. Huawei P20 LCD Screen & Digitizer Replacement, Battery: passo 21, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement, Battery: passo 21, imagem 2 %32 Huawei P20 LCD Screen & Digitizer Replacement, Battery: passo 21, imagem 3 %32
    • Use a spudger to pry up and disconnect the power and volume button flex connector.
    Pergunte ao FixBot
    Comentar
  22. Huawei P20 LCD Screen & Digitizer Replacement: passo 22, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 22, imagem 2 %32
    • Use a spudger to pry up and disconnect the display flex connector and fold the display cable out of your way to remove the battery.
    Pergunte ao FixBot
    Comentar
  23. Huawei P20 LCD Screen & Digitizer Replacement: passo 23, imagem 1 %32
    • Apply a heated iOpener to the screen to loosen the adhesive beneath the battery. Apply the iOpener for at least two minutes.
    • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    Pergunte ao FixBot
    Comentar
  24. Huawei P20 LCD Screen & Digitizer Replacement: passo 24, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 24, imagem 2 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 24, imagem 3 %32
    Plastic Cards
    $2.99
    • Start to slide a plastic card under the bottom right corner of the battery to cut the adhesive.
    • Slide the plastic card along the right side of the battery to further release the adhesive. Gently start to pry up the battery while doing so.
    • If you have trouble prying up the battery, the adhesive may not be loose enough. You can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for about two minutes to help weaken the adhesive.
    Pergunte ao FixBot
    Comentar
  25. Huawei P20 LCD Screen & Digitizer Replacement: passo 25, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 25, imagem 2 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 25, imagem 3 %32
    • Slide the plastic card under the whole upper part of the battery and cut the adhesive with it.
    • Slide the plastic card down to the bottom end of the battery to cut the remaining adhesive.
    • Use the plastic card to pry up the battery.
    Pergunte ao FixBot
    Comentar
  26. Huawei P20 LCD Screen & Digitizer Replacement: passo 26, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 26, imagem 2 %32
    Tesa 61395 Tape
    $8.95
    Pergunte ao FixBot
    Comentar
  27. Huawei P20 LCD Screen & Digitizer Replacement, Daughterboard: passo 27, imagem 1 %32
    • Remove the two Phillips #00 screws (3.4 mm length).
    Pergunte ao FixBot
    Comentar
  28. Huawei P20 LCD Screen & Digitizer Replacement: passo 28, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 28, imagem 2 %32
    • Use a pair of tweezers to disconnect the black coax cable and fold it out of your way.
    Pergunte ao FixBot
    Comentar
  29. Huawei P20 LCD Screen & Digitizer Replacement: passo 29, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 29, imagem 2 %32
    • Use a pair of tweezers to remove the daughterboard.
    Pergunte ao FixBot
    Comentar
  30. Huawei P20 LCD Screen & Digitizer Replacement, Loudspeaker: passo 30, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  31. Huawei P20 LCD Screen & Digitizer Replacement: passo 31, imagem 1 %32
    • Apply a heated iOpener to the bottom end of the screen to loosen the adhesive underneath the loudspeaker. Apply the iOpener for at least two minutes.
    Pergunte ao FixBot
    Comentar
  32. Huawei P20 LCD Screen & Digitizer Replacement: passo 32, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 32, imagem 2 %32
    • Use one arm of a pair of tweezers to peel up the contact cable of the loudspeaker.
    Pergunte ao FixBot
    Comentar
  33. Huawei P20 LCD Screen & Digitizer Replacement: passo 33, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 33, imagem 2 %32
    • Insert a spudger between the midframe and the right side of the loudspeaker.
    • Use the spudger to pry up the loudspeaker.
    Pergunte ao FixBot
    Comentar
  34. Huawei P20 LCD Screen & Digitizer Replacement: passo 34, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 34, imagem 2 %32
    • Remove the loudspeaker.
    Pergunte ao FixBot
    Comentar
  35. Huawei P20 LCD Screen & Digitizer Replacement, Screen: passo 35, imagem 1 %32
    • Apply a heated iOpener to the screen and all edges of the phone to loosen the adhesive beneath the edges of the LCD screen and digitizer. Apply the iOpener for at least two minutes.
    Pergunte ao FixBot
    Comentar
  36. Huawei P20 LCD Screen & Digitizer Replacement: passo 36, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 36, imagem 2 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 36, imagem 3 %32
    • Once the screen is warm to the touch, apply a suction cup to the upper edge of the phone.
    • Pull the suction cup upwards and insert an opening pick in the gap between the display glass and the plastic bezel. Start to cut the adhesive by sliding the opening pick to the top left corner.
    • Make sure you get in the right gap between the display and the plastic bezel. Do not pry between the bezel and the midframe.
    Pergunte ao FixBot
    Comentar
  37. Huawei P20 LCD Screen & Digitizer Replacement: passo 37, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 37, imagem 2 %32
    • Insert a second opening pick and slide it to the top right corner of the phone.
    • Leave the picks in their place to prevent the adhesive from resealing.
    Pergunte ao FixBot
    Comentar
  38. Huawei P20 LCD Screen & Digitizer Replacement: passo 38, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 38, imagem 2 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 38, imagem 3 %32
    • Insert a third opening pick under the top right corner of the phone.
    • Slide the opening pick down to the bottom right corner to cut the adhesive. Leave it at the bottom right corner to prevent the adhesive from resealing.
    • If cutting becomes too difficult, reheat and reapply the iOpener.
    Pergunte ao FixBot
    Comentar
  39. Huawei P20 LCD Screen & Digitizer Replacement: passo 39, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 39, imagem 2 %32
    • Insert the tip of a fourth opening pick at the bottom right corner.
    • Slide the opening pick along the bottom edge of the phone to cut the adhesive.
    • When nearing the fingerprint sensor, only work with the tip of the opening pick to avoid damaging the fingerprint sensor flex cable.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
    Pergunte ao FixBot
    Comentar
  40. Huawei P20 LCD Screen & Digitizer Replacement: passo 40, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 40, imagem 2 %32
    • Insert a fifth opening pick and slide it along the left edge of the phone to cut the remaining adhesive.
    • Try not to remove the display all the way yet, the display cable is still threaded through the frame and adhered on the inner side of the midframe.
    Pergunte ao FixBot
    Comentar
  41. Huawei P20 LCD Screen & Digitizer Replacement: passo 41, imagem 1 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 41, imagem 2 %32 Huawei P20 LCD Screen & Digitizer Replacement: passo 41, imagem 3 %32
    • Thread the display flex cable through the gap in the midframe and remove the display.
    • Before installing a new display, it's important to remove all traces of the old adhesive from the frame, and clean the glued areas with isopropyl alcohol (>90%) and a lint-free cloth.
    • In case your replacement screen isn't equipped with a new home button with fingerprint sensor, follow this guide to remove the button from your old screen.
    Pergunte ao FixBot
    Comentar
Conclusão
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
10 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
261.060 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 28.236 guias
3Comentários do guia
What size tape do you use to reapply?
Tim Bottomley - Responder Compartilhar
The battery doesn't need to be replaced. Taking it out is entirely unnecessary and the relevant steps in this guide can simply be skipped.
Astrodoge - Responder Compartilhar
Hi Astrodoge,
that‘s right. However due to the phone’s design, we recommend removing the lithium-ion battery in order to remove the screen and have better access to the components. We mention this in the introduction of this guide.
Dominik Schnabelrauch - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 30
Últimos 30 dias: 143
Ao todo: 22,814
