Introdução
Use this guide to replace the motherboard in your Huawei P10 Lite smartphone.
O que você precisa
Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
Use a SIM card removal bit or tool and push it into the small hole in the SIM card tray.
Remove the SIM card tray.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
8 outras pessoas executaram este guia.
2 comentários
I need huawei p10 lite board 4gb 64gb
