Ir para o conteúdo principal
How to replace the Azpen A720 Wi-Fi Antenna
O que você precisa
  1. How to replace the Azpen A720 Wi-Fi Antenna, Back Cover: passo 1, imagem 1 %32 How to replace the Azpen A720 Wi-Fi Antenna, Back Cover: passo 1, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
    Pergunte ao FixBot
    Comentar
  2. How to replace the Azpen A720 Wi-Fi Antenna: passo 2, imagem 1 %32 How to replace the Azpen A720 Wi-Fi Antenna: passo 2, imagem 2 %32 How to replace the Azpen A720 Wi-Fi Antenna: passo 2, imagem 3 %32
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
    Pergunte ao FixBot
    Comentar
  3. How to replace the Azpen A720 Wi-Fi Antenna: passo 3, imagem 1 %32
    • Remove the rear casing.
    Pergunte ao FixBot
    Comentar
  4. How to replace the Azpen A720 Wi-Fi Antenna, Wi-Fi Antenna: passo 4, imagem 1 %32
    • Locate the gray cord attached to the motherboard and the battery. This is the wifi antenna.
    Pergunte ao FixBot
    Comentar
  5. How to replace the Azpen A720 Wi-Fi Antenna: passo 5, imagem 1 %32 How to replace the Azpen A720 Wi-Fi Antenna: passo 5, imagem 2 %32
    • Locate the soldering connection between the wifi antenna and the motherboard.
    • Using a soldering iron, melt the soldering connection between the cord and the motherboard and disconnect the cord.
    • The soldering iron gets very hot, be careful not to touch the tip to avoid burns. Click here to learn how to solder.
    Pergunte ao FixBot
    Comentar
  6. How to replace the Azpen A720 Wi-Fi Antenna: passo 6, imagem 1 %32 How to replace the Azpen A720 Wi-Fi Antenna: passo 6, imagem 2 %32
    • Locate the black sticker connecting the wifi antenna to the battery.
    • Peel the black sticker off of the battery to disconnect the wifi antenna.
    • Remove and replace the defective wire.
    Pergunte ao FixBot
    Comentar
Conclusão
Anna
Membro desde: 03/17/15
353 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 30
Ao todo: 1,451
