Ir para o conteúdo principal
How to Use a Desoldering Pump
O que você precisa
  1. How to Use a Desoldering Pump, Prime the pump: passo 1, imagem 1 %32 How to Use a Desoldering Pump, Prime the pump: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    Desoldering Pump
    $3.99
    • If this is your first time using a desoldering pump, try priming and activating the pump a few times before you use it for desoldering purposes.
    • Firmly grasp the desoldering pump with your hand.
    • Depress the plunger until it locks in place.
    • This primes the spring-loaded piston for suction.
  2. How to Use a Desoldering Pump, Activate the pump: passo 2, imagem 1 %32 How to Use a Desoldering Pump, Activate the pump: passo 2, imagem 2 %32
    • To activate the pump, press the black side button.
    • This releases the spring-loaded piston, which creates a burst of suction at the nozzle.
    • The piston release creates a substantial kickback. Brace your hand when you use the pump to keep the nozzle steady.
  3. How to Use a Desoldering Pump, Desolder a joint: passo 3, imagem 1 %32 How to Use a Desoldering Pump, Desolder a joint: passo 3, imagem 2 %32 How to Use a Desoldering Pump, Desolder a joint: passo 3, imagem 3 %32
    FixHub | Power Series Smart Soldering Iron
    $79.95
    • Do not use the desoldering pump to desolder joints near small surface-mounted (SMT) components. The heat spillover and suction may dislodge the SMT components.
    • Prime the desoldering pump by depressing the plunger.
    • Heat the solder joint until the solder is liquified. To help with heat transfer, add some solder onto the soldering iron's tip.
    • Position the pump's nozzle as close to the molten solder as possible.
    • The nozzle is made of heat-resistant plastic, so don't worry if you occasionally brush the tip with it.
    • Press the side button to activate the pump.
    • Repeat the process until the joint is clean. You can also use solder wick to help soak up any remnant solder.
  4. How to Use a Desoldering Pump, Clean the desoldering pump: passo 4, imagem 1 %32 How to Use a Desoldering Pump, Clean the desoldering pump: passo 4, imagem 2 %32 How to Use a Desoldering Pump, Clean the desoldering pump: passo 4, imagem 3 %32
    • To clean the pump, prime and activate the pump a few times. This pushes a rod through the nozzle and ensures that solder doesn't block it.
    • On the rare occasion when the pump needs a more thorough cleaning, you can disassemble the pump to clean it out:
    • Grasp the nozzle by its knurled edge.
    • Twist the nozzle counter-clockwise to unscrew it. This may be difficult due to a tight-fitting O-ring.
    • Remove the nozzle and clean out the pump interior.
Conclusão
For soldering instructions and tips, follow this guide.
82 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
309.541 Reputação
Autoria de 701 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.608 guias
4Comentários do guia
Good review, but I’ve found that these small solder suckers don’t do a very good job. The much larger “Soldapult” (https://www.edsyn.com/product/DS017.html) provides much more suction and can often completely clear a joint in one use.
shamino - Responder
How does the tip not melt.
Mia Cipollone - Responder
Apply higher temperature on your soldering iron, above 380°C.
Use bigger tip, bigger heating surface provides more effecitive heat transfer.
SchwarzeKatz -
If you are asking about why the tip of the solder sucker doesn't melt, it is made of a heat resitant material. Notice the word resistant.
Budda Belly - Responder
Comentar
Visualizações:
Últimas 24 horas: 60
Últimos 7 dias: 489
Últimos 30 dias: 1,980
Ao todo: 104,454
