Ir para o conteúdo principal
How to Use Suction Tape
  1. How to Use Suction Tape, Choose the tape: passo 1, imagem 1 %32 How to Use Suction Tape, Choose the tape: passo 1, imagem 2 %32
    • If you want to secure one side of your two-panel device, skip to this step.
    • If you to buffer a difficult surface on your device, move to the next step.
  2. How to Use Suction Tape, Measure the tape: passo 2, imagem 1 %32 How to Use Suction Tape, Measure the tape: passo 2, imagem 2 %32 How to Use Suction Tape, Measure the tape: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • Measure the length of tape you want and mark it with a pen. Consider the following:
    • You need enough tape for the Anti-Clamp's suction cups. Don't leave gaps, or the cups won't stick.
    • Don't use too much tape so it folds over your phone's edges. This may interfere with the opening procedure.
  3. How to Use Suction Tape, Cut the tape: passo 3, imagem 1 %32 How to Use Suction Tape, Cut the tape: passo 3, imagem 2 %32 How to Use Suction Tape, Cut the tape: passo 3, imagem 3 %32
    • Use scissors to cut the tape to the desired length.
    • Repeat the measuring and cutting procedure for each piece of tape required.
  4. How to Use Suction Tape, Peel the tape: passo 4, imagem 1 %32 How to Use Suction Tape, Peel the tape: passo 4, imagem 2 %32
    • Peel the tape off its plastic liner.
  5. How to Use Suction Tape, Apply the tape: passo 5, imagem 1 %32 How to Use Suction Tape, Apply the tape: passo 5, imagem 2 %32 How to Use Suction Tape, Apply the tape: passo 5, imagem 3 %32
    • Apply the tape to the panel of your device where you'll attach the Anti-Clamp.
  6. How to Use Suction Tape, Secure the tape: passo 6, imagem 1 %32 How to Use Suction Tape, Secure the tape: passo 6, imagem 2 %32 How to Use Suction Tape, Secure the tape: passo 6, imagem 3 %32
    • Use the flat end of a spudger, or your finger, to completely secure the tape to your device.
    • Use a spudger to press out any large bubbles.
  7. How to Use Suction Tape, Open the device: passo 7, imagem 1 %32 How to Use Suction Tape, Open the device: passo 7, imagem 2 %32
    • Repeat the tape measuring, cutting, and applying process for the opposite side of your device.
    • You're now ready to open your device!
    • Follow this guide for general instructions on how to use the Anti-Clamp.
  8. How to Use Suction Tape, Measure the tape: passo 8, imagem 1 %32 How to Use Suction Tape, Measure the tape: passo 8, imagem 2 %32 How to Use Suction Tape, Measure the tape: passo 8, imagem 3 %32
    • The remaining steps show how to secure one side of your two-panel device.
    • Choose which panel of the device you don't want to open, and the following steps will show how to secure it.
    • In this example, we want to open the screen, so we'll secure the blue back cover.
    • You need to leave room for the Anti-Clamp's suction cups—don't place tape under them, or they won't stick.
    • Use enough tape to ensure a good hold on the panel you don't want to open.
    • Don't cover the power button with tape, or you might accidentally turn on the device.
  9. How to Use Suction Tape, Peel the tape: passo 9, imagem 1 %32 How to Use Suction Tape, Peel the tape: passo 9, imagem 2 %32
  10. How to Use Suction Tape, Cut the tape: passo 10, imagem 1 %32 How to Use Suction Tape, Cut the tape: passo 10, imagem 2 %32
  11. How to Use Suction Tape, Apply the tape: passo 11, imagem 1 %32 How to Use Suction Tape, Apply the tape: passo 11, imagem 2 %32 How to Use Suction Tape, Apply the tape: passo 11, imagem 3 %32
    • Apply the tape to the edges of your device nearest to where you'll attach the Anti-Clamp.
    • Don't fold the tape over the panel you want to open, as this might hinder the opening procedure.
  12. How to Use Suction Tape, Fold the tape: passo 12, imagem 1 %32 How to Use Suction Tape, Fold the tape: passo 12, imagem 2 %32 How to Use Suction Tape, Fold the tape: passo 12, imagem 3 %32
    • Fold the tape onto the panel you don't want to open.
    • Use your fingers to press down the tape and firmly secure it to your device.
  13. How to Use Suction Tape, Open the device: passo 13, imagem 1 %32 How to Use Suction Tape, Open the device: passo 13, imagem 2 %32
Conclusão
For other general electronics skills guides, click here.
5 outras pessoas executaram este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
161.984 Reputação
Autoria de 769 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.413 guias
2 comentários
Does anybody know the brand/type of tape? Searching for "suction tape" online leads to a different product.
Arturo - Responder
I suggest "carpet tape", used to join carpet sections together and often used for temporary joins in wood and metal working setups; or maybe Gorilla brand gaffer tape which is very grippy and has lots of reinforceing fiber strands for low stretch, (useing it now to hold the hinges of a laptop together till I get it fixed properly). Both can be found in most hardware/home care stores in USA. Cleanup of adhesive residue maybe a pain, requireing "goo gone" or WD-40 followed by alcohol wipes.
Kevin Smith - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 76
Últimos 30 dias: 259
Duração total: 6,647
