Introdução
Follow these instructions to use suction tape during Anti-Clamp opening procedures.
Suction tape has two uses: to buffer a difficult surface and to secure one side of a two-panel device. If you don't have the suction tape included with the Anti-Clamp, you can also use smooth adhesive strips like packing tape.
Difficult surfaces can be broken screens, slippery back covers, or anything that prevents the Anti-Clamp from securing properly.
Most devices open from only one side (or "panel")—but some, like the iPhone 14, give you the option of opening either side. Since the Anti-Clamp pulls on both sides simultaneously, it may accidentally separate the wrong side, or both sides.
Note: this guide uses the iPhone 14 as an example; your device may vary in length, roundness, and button placement, but the procedure should be the same.
Ferramenta utilizada neste passo:Clampy - Anti-Clamp$24.95
Measure the length of tape you want and mark it with a pen. Consider the following:
You need enough tape for the Anti-Clamp's suction cups. Don't leave gaps, or the cups won't stick.
Don't use too much tape so it folds over your phone's edges. This may interfere with the opening procedure.
Use scissors to cut the tape to the desired length.
Repeat the measuring and cutting procedure for each piece of tape required.
Apply the tape to the panel of your device where you'll attach the Anti-Clamp.
Use the flat end of a spudger, or your finger, to completely secure the tape to your device.
Use a spudger to press out any large bubbles.
Repeat the tape measuring, cutting, and applying process for the opposite side of your device.
You're now ready to open your device!
Follow this guide for general instructions on how to use the Anti-Clamp.
Choose which panel of the device you don't want to open, and the following steps will show how to secure it.
You need to leave room for the Anti-Clamp's suction cups—don't place tape under them, or they won't stick.
Use enough tape to ensure a good hold on the panel you don't want to open.
Apply the tape to the edges of your device nearest to where you'll attach the Anti-Clamp.
Fold the tape onto the panel you don't want to open.
Use your fingers to press down the tape and firmly secure it to your device.
For other general electronics skills guides, click here.
7 outras pessoas executaram este guia.
3Comentários do guia
Does anybody know the brand/type of tape? Searching for "suction tape" online leads to a different product.
I suggest "carpet tape", used to join carpet sections together and often used for temporary joins in wood and metal working setups; or maybe Gorilla brand gaffer tape which is very grippy and has lots of reinforceing fiber strands for low stretch, (useing it now to hold the hinges of a laptop together till I get it fixed properly). Both can be found in most hardware/home care stores in USA. Cleanup of adhesive residue maybe a pain, requireing "goo gone" or WD-40 followed by alcohol wipes.
I would like to check the material of this product. Anyone can help me?
