Ir para o conteúdo principal
How to Tighten Your Samsung Refrigerator Door Handles
O que você precisa
  1. How to Tighten Your Samsung Refrigerator Door Handles, Tighten the door handle: passo 1, imagem 1 %32
    • Follow this step to tighten a loose door handle.
    • Use a hex driver to tighten the set screw securing the door handle to the refrigerator.
    • The set screw is normally near the end of the handle where it connects to the refrigerator.
    • This screw is commonly 2.5 mm hex size, but may vary depending on the refrigerator.
  2. How to Tighten Your Samsung Refrigerator Door Handles, Remove the door handle: passo 2, imagem 1 %32 How to Tighten Your Samsung Refrigerator Door Handles, Remove the door handle: passo 2, imagem 2 %32 How to Tighten Your Samsung Refrigerator Door Handles, Remove the door handle: passo 2, imagem 3 %32
    • Follow this step if you want to remove or replace the door handle.
    • Use a hex driver to remove the set screw securing the door handle to the refrigerator.
    • Lift the handle off of the screw post and remove it.
Conclusão
Arthur Shi
Membro desde: 01/03/18
309.522 Reputação
Autoria de 701 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.608 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 80
Ao todo: 4,390
