Ir para o conteúdo principal
How to Install an M.2 SSD
O que você precisa
  1. How to Install an M.2 SSD, Reposition the standoff: passo 1, imagem 1 %32 How to Install an M.2 SSD, Reposition the standoff: passo 1, imagem 2 %32
    • If your laptop did not include a removable standoff or only supports one M.2 SSD form factor, you can skip this step.
    • Use a screwdriver to remove the preinstalled standoff.
    • If your laptop does not include a preinstalled standoff, you will need to get one.
    • Find the correct standoff location that corresponds to your desired M.2 SSD form factor.
    • Screw in the standoff.
  2. How to Install an M.2 SSD, Insert the SSD: passo 2, imagem 1 %32 How to Install an M.2 SSD, Insert the SSD: passo 2, imagem 2 %32 How to Install an M.2 SSD, Insert the SSD: passo 2, imagem 3 %32
    • Grip the SSD on the sides near the screw indent.
    • Gently slide the SSD into the socket at about a 30˚ angle.
    • The socket is spring loaded and will support the SSD at an angle.
  3. How to Install an M.2 SSD, Screw down the SSD: passo 3, imagem 1 %32 How to Install an M.2 SSD, Screw down the SSD: passo 3, imagem 2 %32 How to Install an M.2 SSD, Screw down the SSD: passo 3, imagem 3 %32
    • Use your finger to hold the SSD down horizontally, making sure that the screw indent aligns with the standoff.
    • Screw down the SSD to secure it.
  4. How to Install an M.2 SSD, Apply a thermal pad: passo 4, imagem 1 %32 How to Install an M.2 SSD, Apply a thermal pad: passo 4, imagem 2 %32 How to Install an M.2 SSD, Apply a thermal pad: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • If your laptop did not have a thermal pad installed, you can skip this step.
    • Use tweezers or your fingers to place a thermal pad on the top of the SSD.
    • The original thermal pad can be reused if it is clean and undamaged.
Conclusão
Installation didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
17 outras pessoas executaram este guia.
Chayton Ritter
Membro desde: 08/21/20
24.955 Reputação
Autoria de 105 guias
2Comentários do guia
muchas gracias por la ayuda amigo dios t bendiga
Jose Percy Castro Carrera - Responder
شكرا على المعلومات موقع رائع
tayeb - Responder
Comentar
Visualizações:
Últimas 24 horas: 17
Últimos 7 dias: 95
Últimos 30 dias: 393
Ao todo: 10,293
