Ir para o conteúdo principal
How to Install a New Battery in Your Samsung Galaxy S22 Ultra
O que você precisa
  1. How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Clean the frame: passo 1, imagem 1 %32 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Clean the frame: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use your fingers or tweezers to peel up and remove any large pieces of adhesive from the frame.
    • Apply a few drops of highly-concentrated isopropyl alcohol (greater than 90%) to the remaining adhesive.
    • Use the flat end of a spudger to scrape off all remaining adhesive.
  2. How to Install a New Battery in Your Samsung Galaxy S22 Ultra: passo 2, imagem 1 %32
    Microfiber Cleaning Cloths
    $3.99
    Comprar
    • Apply a few more drops of highly-concentrated isopropyl alcohol (greater than 90%) to any adhesive residue on the frame and wipe it away with a microfiber or lint-free cloth.
  3. How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Measure and cut the tape: passo 3, imagem 1 %32 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Measure and cut the tape: passo 3, imagem 2 %32 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Measure and cut the tape: passo 3, imagem 3 %32
    Tesa 61395 Tape
    $2.99
    Comprar
  4. How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Apply the strips of tape: passo 4, imagem 1 %32 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Apply the strips of tape: passo 4, imagem 2 %32 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Apply the strips of tape: passo 4, imagem 3 %32
    • Lay a strip of tape onto the frame.
    • Use the flat end of your spudger to press down firmly along the whole strip to secure it.
    • Use tweezers to remove the liner from the strip of tape.
  5. How to Install a New Battery in Your Samsung Galaxy S22 Ultra: passo 5, imagem 1 %32 How to Install a New Battery in Your Samsung Galaxy S22 Ultra: passo 5, imagem 2 %32 How to Install a New Battery in Your Samsung Galaxy S22 Ultra: passo 5, imagem 3 %32
    • Repeat the previous step to apply the remaining strips of tape.
  6. How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Secure the battery: passo 6, imagem 1 %32 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Secure the battery: passo 6, imagem 2 %32 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Secure the battery: passo 6, imagem 3 %32
    • While holding the battery above its recess, reconnect the battery cable.
    • This ensures the battery is properly aligned.
    • Lay the battery into its recess in the frame.
    • Press down firmly on the entire surface of the battery to secure it with the tape.
    • Disconnect the battery.
    • Return to your repair guide and continue reassembly.
Conclusão
For optimal performance, calibrate your newly installed battery after completing your repair.
Spencer Day
Membro desde: 09/14/22
61.610 Reputação
Autoria de 445 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.076 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 47
Últimos 30 dias: 205
Duração total: 1,766
