Ir para o conteúdo principal
How to Install a New Battery in Your Google Pixel 8 Pro
O que você precisa
  1. How to Install a New Battery in Your Google Pixel 8 Pro, Remove the old adhesive from the frame: passo 1, imagem 1 %32 How to Install a New Battery in Your Google Pixel 8 Pro, Remove the old adhesive from the frame: passo 1, imagem 2 %32 How to Install a New Battery in Your Google Pixel 8 Pro, Remove the old adhesive from the frame: passo 1, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • In order for the battery to properly adhere, you must remove all the old adhesive and its residue.
    • Use the flat end of a spudger to scrape up and remove all the old adhesive from the frame.
    • If you're having trouble, apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to the adhesive and scrape it up.
    • Use your fingers or tweezers to pick off big chunks.
  2. How to Install a New Battery in Your Google Pixel 8 Pro, Remove the old adhesive residue: passo 2, imagem 1 %32
    Microfiber Cleaning Cloths
    $3.99
    Comprar
    • Once you've removed all the old adhesive, apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to any residue left on the frame and wipe it away with a microfiber or lint-free cloth.
  3. How to Install a New Battery in Your Google Pixel 8 Pro, Temporarily reconnect the battery: passo 3, imagem 1 %32 How to Install a New Battery in Your Google Pixel 8 Pro, Temporarily reconnect the battery: passo 3, imagem 2 %32
    • Lay the battery in its recess and temporarily reconnect it to the logic board to check its fit and cable length before adhering it.
    • Once you've found the proper alignment, disconnect the battery and remove it.
  4. How to Install a New Battery in Your Google Pixel 8 Pro, Install the battery: passo 4, imagem 1 %32 How to Install a New Battery in Your Google Pixel 8 Pro, Install the battery: passo 4, imagem 2 %32 How to Install a New Battery in Your Google Pixel 8 Pro, Install the battery: passo 4, imagem 3 %32
    Tesa 61395 Tape
    $5.99
    Comprar
    • If your battery comes with adhesive pre-installed, remove the plastic liner and firmly press the battery into its recess to secure it with the adhesive.
    • If your battery doesn't have pre-installed adhesive, apply strips of double-sided tape such as Tesa Tape where the old adhesive was and firmly press the battery into its recess to secure it.
Conclusão
Spencer Day
Membro desde: 09/14/22
61.610 Reputação
Autoria de 445 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.077 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 19
Últimos 30 dias: 81
Duração total: 707
