Ir para o conteúdo principal
How to Force Restart iPhone X
  1. How to Force Restart iPhone X, How to Force Restart iPhone X: passo 1, imagem 1 %32
    • Quickly press and release the volume-up button (1).
    • Quickly press and release the volume-down button (2).
  2. How to Force Restart iPhone X: passo 2, imagem 1 %32
    • Finally, press and hold the side button (3) until the Apple logo appears, and then release.
    • The screen will temporarily go dark as the iPhone shuts down and reboots. Keep holding the button until you see the  logo.
Conclusão
You're done!
137 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
fr en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
14Comentários do guia
You saved my day. My iphoneX did not respond to anything after connect with the itune. I tried to shut down by holding volume up/down + side button but it didn’t work. So I tried your method and it worked!!! Thank you so much
Satit Jan - Responder
This is a temporary solution whenever my iphone gets unresponsive i used this method but after some time it again starts doing same laggy and unresponsive behaviour
Siraj Munir - Responder
good share. thanks.
MelissaR - Responder
What is the other way?
sa sas - Responder
will it delete all data from my iPhone?
_TR0xuu_ - Responder
Comentar
Visualizações:
Últimas 24 horas: 15
Últimos 7 dias: 89
Últimos 30 dias: 497
Ao todo: 370,960
