Ir para o conteúdo principal
How to Fix Logitech G403 Double Click Issue
O que você precisa
  1. How to Fix Logitech G403 Double Click Issue, How to Fix Logitech G403 Double Click Issue: passo 1, imagem 1 %32
    • Use a prying tool or your hand to take out both sides of the mouse feet.
    Pergunte ao FixBot
    Comentar
  2. How to Fix Logitech G403 Double Click Issue: passo 2, imagem 1 %32
    • Use a precision screwdriver to remove four screws from the mouse.
    Pergunte ao FixBot
    Comentar
  3. How to Fix Logitech G403 Double Click Issue: passo 3, imagem 1 %32 How to Fix Logitech G403 Double Click Issue: passo 3, imagem 2 %32
    • Slowly open the mouse, and take care not to tear the ribbon cable.
    • Detach the cable connector.
    Pergunte ao FixBot
    Comentar
  4. How to Fix Logitech G403 Double Click Issue: passo 4, imagem 1 %32 How to Fix Logitech G403 Double Click Issue: passo 4, imagem 2 %32
    • Remove seven screws from the upper cover.
    Pergunte ao FixBot
    Comentar
  5. How to Fix Logitech G403 Double Click Issue: passo 5, imagem 1 %32 How to Fix Logitech G403 Double Click Issue: passo 5, imagem 2 %32
    • Remove four screws from the mouse.
    • Remove the mouse click cover.
    Pergunte ao FixBot
    Comentar
  6. How to Fix Logitech G403 Double Click Issue: passo 6, imagem 1 %32 How to Fix Logitech G403 Double Click Issue: passo 6, imagem 2 %32
    • Remove the five screws attached to the mouse click switches.
    Pergunte ao FixBot
    Comentar
  7. How to Fix Logitech G403 Double Click Issue: passo 7, imagem 1 %32 How to Fix Logitech G403 Double Click Issue: passo 7, imagem 2 %32
    • Open the mouse switch using a prying tool or your hands.
    • Be careful not to lose the white plastic part from the mouse switch.
    Pergunte ao FixBot
    Comentar
  8. How to Fix Logitech G403 Double Click Issue: passo 8, imagem 1 %32 How to Fix Logitech G403 Double Click Issue: passo 8, imagem 2 %32
    • Find the place where more tension is needed.
    • Use a prying tool or your hand to give more tension to the copper piece, making sure the copper is curved.
    Pergunte ao FixBot
    Comentar
Conclusão
10 outras pessoas executaram este guia.
Jisuk Kang
Membro desde: 07/05/20
415 Reputação
Autoria de 1 guia
Equipe
10Comentários do guia
step 8 made no sense and had to google it
rel - Responder Compartilhar
did you find a video about that? if you could send it pls or if it was some place where talk more about it
Lian López - Responder Compartilhar
Worked!!! I had this problem for years, even stoped playing valorant bacause of that. Thanks
VampireKing - Responder Compartilhar
I could not open these screws :( What are the screwdriver size to open these?
Siim - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 43
Últimos 30 dias: 182
Ao todo: 36,849
