Introdução
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to apply new back cover adhesive in your Google Pixel 8a following a repair.
Follow this guide to remove the back cover, if you haven't done so already.
O que você precisa
Use a spudger and tweezers to scrape up and remove all the old back cover adhesive from the entire perimeter of the frame.
Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the perimeter of the frame and the area where the two smaller adhesive strips were.
Wipe any adhesive residue away using a microfiber or lint-free cloth.
If you're reusing your back cover, use the same process to clean up any adhesive residue.
Remove the shorter, wider strip of back cover adhesive from its liner and place it on the plastic housing just above the rear cameras.
Align the back cover over the frame and press it into place.
Firmly press around the perimeter of the back cover to secure it.
