Ir para o conteúdo principal
Hover-1 Eagle Front Wheel Replacement
O que você precisa
    1. Hover-1 Eagle Front Wheel Replacement, Front Wheel: passo 1, imagem 1 %32
      • Wedge the spudger underneath the red reflective sticker and peel it back.
      Pergunte ao FixBot
      Comentar
    2. Hover-1 Eagle Front Wheel Replacement: passo 2, imagem 1 %32 Hover-1 Eagle Front Wheel Replacement: passo 2, imagem 2 %32
      • Remove the four 2mm screws with a Phillips #2 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Hover-1 Eagle Front Wheel Replacement: passo 3, imagem 1 %32
      • Remove the plastic axle cover by sliding the cover downwards.
      Pergunte ao FixBot
      Comentar
    4. Hover-1 Eagle Front Wheel Replacement: passo 4, imagem 1 %32
      • Use pliers to remove the locknut.
      Pergunte ao FixBot
      Comentar
    5. Hover-1 Eagle Front Wheel Replacement: passo 5, imagem 1 %32
      • Slide the wheel out in a downwards motion to remove it from the fork.
      Pergunte ao FixBot
      Comentar
Conclusão
5 outras pessoas executaram este guia.
Andrew Gaskell
Membro desde: 01/23/20
1.137 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S1-G2, White Winter 2020 Membro de Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Membros
Autoria de 6 guias
18Comentários do guia
Good afternoon.
And how do you remove the cables?
Diogo Silva - Responder Compartilhar
i would like to know the same thing
it'sluigiplays 87 - Responder Compartilhar
where do i get the front wheel front i cant find where to buy a new front wheel
leon watts - Responder Compartilhar
I would like to know as well how to take the cable out from harness. Do you have to remove everything from the battery and disconnect the throttle as well?
Mk Sub-zero - Responder Compartilhar
Does anybody know how to fix the handlebar/front wheel alignment?
robandkim - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 80
Ao todo: 8,025
