Ir para o conteúdo principal
Hover-1 Charger Gyroscope Sensor Board Replacement
O que você precisa
    1. Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: passo 1, imagem 1 %32 Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: passo 1, imagem 2 %32
      • Flip the hoverboard over so that the warning label is facing up.
      • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
      • Remove the four 10 mm screws with a Phillips #2 screwdriver.
      • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Hover-1 Charger Gyroscope Sensor Board Replacement: passo 2, imagem 1 %32
      • Pull the right cover away from the hoverboard to expose the battery.
      Pergunte ao FixBot
      Comentar
    3. Hover-1 Charger Gyroscope Sensor Board Replacement: passo 3, imagem 1 %32 Hover-1 Charger Gyroscope Sensor Board Replacement: passo 3, imagem 2 %32
      • Disconnect the two pronged black and yellow cable.
      Pergunte ao FixBot
      Comentar
    4. Hover-1 Charger Gyroscope Sensor Board Replacement: passo 4, imagem 1 %32
      • Pull the left cover away from the hoverboard.
      Pergunte ao FixBot
      Comentar
    5. Hover-1 Charger Gyroscope Sensor Board Replacement: passo 5, imagem 1 %32 Hover-1 Charger Gyroscope Sensor Board Replacement: passo 5, imagem 2 %32
      • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
      Pergunte ao FixBot
      Comentar
    1. Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: passo 6, imagem 1 %32 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: passo 6, imagem 2 %32 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: passo 6, imagem 3 %32
      • Unplug the white five pin connector from the gyroscope sensor board.
      • Unplug the red, yellow, blue, green, black and white six pin connector.
      • Unplug the black and red two pin connector.
      • Unplug the black, yellow, green and red four pin connector. Unplugging this connector is photographed as an example.
      Pergunte ao FixBot
      Comentar
    2. Hover-1 Charger Gyroscope Sensor Board Replacement: passo 7, imagem 1 %32 Hover-1 Charger Gyroscope Sensor Board Replacement: passo 7, imagem 2 %32
      • Remove the four 10 mm screws from the gyroscope sensor board with a Phillips #2 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Hover-1 Charger Gyroscope Sensor Board Replacement: passo 8, imagem 1 %32 Hover-1 Charger Gyroscope Sensor Board Replacement: passo 8, imagem 2 %32 Hover-1 Charger Gyroscope Sensor Board Replacement: passo 8, imagem 3 %32
      • Push the rubber sheaths away from the clasp of the green bullet connector.
      • Grasp the connector at the metal junction and disconnect.
      • Repeat for the yellow and red bullet connectors.
      • There may be a zip tie holding these wires together. Cut this off.
      • These bullet connectors may be hard to disconnect; do not be afraid to pull with strong force.
      Pergunte ao FixBot
      Comentar
    4. Hover-1 Charger Gyroscope Sensor Board Replacement: passo 9, imagem 1 %32
      • Remove the gyroscope sensor board.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Melanie Hardell
Membro desde: 10/10/19
517 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S12-G1, Regan Fall 2019 Membro de Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Membros
Autoria de 6 guias
5Comentários do guia
Hi Where can I find the replacement sensor board? Thanks!
Jason LaDuke - Responder Compartilhar
where do i find the replacement sensor board?
one wheel of my board doesn’t work
Philip Donkoh - Responder Compartilhar
I need one of these replacement gyros please how I get
Matthew Isaiah Cowart - Responder Compartilhar
Worthless guide. No instructions on where to get the replacement gyro boards
Fuckaboi - Responder Compartilhar
this is a joke. 2 years still not one kind enough soul to help find where to purchase replacements!!!!!!!!
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 35
Ao todo: 6,106
