Ir para o conteúdo principal
Hover-1 Charger Battery Replacement
O que você precisa
  1. Hover-1 Charger Battery Replacement, Battery: passo 1, imagem 1 %32 Hover-1 Charger Battery Replacement, Battery: passo 1, imagem 2 %32
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Hover-1 Charger Battery Replacement: passo 2, imagem 1 %32
    • Pull the right cover away from the hoverboard to expose the battery.
    Pergunte ao FixBot
    Comentar
  3. Hover-1 Charger Battery Replacement: passo 3, imagem 1 %32 Hover-1 Charger Battery Replacement: passo 3, imagem 2 %32
    • Unplug the battery by disconnecting the two pronged black and yellow cable.
    Pergunte ao FixBot
    Comentar
  4. Hover-1 Charger Battery Replacement: passo 4, imagem 1 %32
    • Pull the left cover away from the hoverboard.
    Pergunte ao FixBot
    Comentar
  5. Hover-1 Charger Battery Replacement: passo 5, imagem 1 %32 Hover-1 Charger Battery Replacement: passo 5, imagem 2 %32
    • Disconnect the two pronged black and yellow cable.
    • Thread the cable through the middle cylinder of the hoverboard.
    Pergunte ao FixBot
    Comentar
  6. Hover-1 Charger Battery Replacement: passo 6, imagem 1 %32 Hover-1 Charger Battery Replacement: passo 6, imagem 2 %32
    • Unscrew the four 10mm screws that are holding the battery casing in place. Use a Phillips #2 screwdriver.
    • If there is a zip-tie connecting the wires together, carefully cut it with a wire cutters.
    Pergunte ao FixBot
    Comentar
  7. Hover-1 Charger Battery Replacement: passo 7, imagem 1 %32 Hover-1 Charger Battery Replacement: passo 7, imagem 2 %32 Hover-1 Charger Battery Replacement: passo 7, imagem 3 %32
    • On the battery side, unplug the white five pin connector on the circuitboard.
    • Unplug the black, yellow, green and red connector on the circuitboard.
    Pergunte ao FixBot
    Comentar
  8. Hover-1 Charger Battery Replacement: passo 8, imagem 1 %32
    • Move all the loose cables to the side. Pull the battery casing away from the battery.
    Pergunte ao FixBot
    Comentar
  9. Hover-1 Charger Battery Replacement: passo 9, imagem 1 %32
    • Use the opening tool to remove the battery from the metal casing.
    • The battery is stuck to the metal casing with strong adhesive; do not be afraid to apply a strong force with the opening tool.
    Pergunte ao FixBot
    Comentar
  10. Hover-1 Charger Battery Replacement: passo 10, imagem 1 %32
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S12-G1, Regan Fall 2019 Membro de Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Membros
Autoria de 6 guias
1Comentário do guia
Can I replace my battery 25.2v to a 36v.
Airie Green - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 43
Últimos 30 dias: 103
Ao todo: 10,506
