Ir para o conteúdo principal
Honeywell Turboforce Motor Replacement
O que você precisa
  1. Honeywell Turboforce Motor Replacement, Motor: passo 1, imagem 1 %32 Honeywell Turboforce Motor Replacement, Motor: passo 1, imagem 2 %32 Honeywell Turboforce Motor Replacement, Motor: passo 1, imagem 3 %32
    • Using a Phillips #1 screwdriver, remove the six 15mm screws on the outer ring of the back of the fan holding the frame together.
    • The screw channel is long and it is recommended to use a screwdriver with a long shaft or a screwdriver with a skinnier handle.
  2. Honeywell Turboforce Motor Replacement: passo 2, imagem 1 %32 Honeywell Turboforce Motor Replacement: passo 2, imagem 2 %32 Honeywell Turboforce Motor Replacement: passo 2, imagem 3 %32
    • Pry apart the blade cover from the body of the fan to access the inside.
  3. Honeywell Turboforce Motor Replacement: passo 3, imagem 1 %32 Honeywell Turboforce Motor Replacement: passo 3, imagem 2 %32
    • Remove the two 36mm screws on the metal plate behind the blades using the Phillips #1 screwdriver.
  4. Honeywell Turboforce Motor Replacement: passo 4, imagem 1 %32 Honeywell Turboforce Motor Replacement: passo 4, imagem 2 %32
    • Carefully pull the motor forward out of its resting position and tilt it forward revealing the back of the motor.
    • Beware of the wires attached to the back of the motor.
  5. Honeywell Turboforce Motor Replacement: passo 5, imagem 1 %32 Honeywell Turboforce Motor Replacement: passo 5, imagem 2 %32 Honeywell Turboforce Motor Replacement: passo 5, imagem 3 %32
    • Using the Phillips #1 screwdriver, remove the two 37mm screws on the back of the motor.
    • Beware that there is a nut holding the screw in place on the opposite side of the motor.
    • Beware once the screw is removed the metal brace where the screws are located will come off.
  6. Honeywell Turboforce Motor Replacement: passo 6, imagem 1 %32 Honeywell Turboforce Motor Replacement: passo 6, imagem 2 %32
    • Carefully remove the circular motor from the square holder.
    • The fan blades will still be connected to the circular motor.
  7. Honeywell Turboforce Motor Replacement: passo 7, imagem 1 %32 Honeywell Turboforce Motor Replacement: passo 7, imagem 2 %32 Honeywell Turboforce Motor Replacement: passo 7, imagem 3 %32
    • Remove the felt washer, metal washer, and the rubber stopper from the axle.
  8. Honeywell Turboforce Motor Replacement: passo 8, imagem 1 %32
    • Remove the motor and replace it with the new part.
    • Consider using a lubricant to insert the new motor.
    Very helpful and systematic. Thought I needed a new motor. Turns out all I needed was a cleaning and some WD40
    Krupal Shah - Responder
    Any links or pointers where to get this replacement motor? I’m looking to replace 120v with 240v any thoughts ?
    Dario Matonicki - Responder
    The fan you are replacing is NOT the same as what I own. Mine is a model HV180. It looks similar but is 19" OD and has a 2part housing that looks to be a bare to open. Looks best to cut the little wire angles off and replace the motor. To reassemble put it together with zip ties and then use a mig welder to make it firmer and safer for a longer life!!
    McGyver - Responder
Conclusão
11 outras pessoas executaram este guia.
6 comentários
What is the motor parts details to procure elsewhere?
patra gyanesh - Responder
Hi informative guide but first how do we get the new motor how do you remove the blade nut to remove the blade from the old motor shaft
Dave Gordon - Responder
Given the difficulty of finding a replacement motor with three speeds and the correct mounting configuration, it makes more sense to buy a new model of this fan. Much faster, too.
Sprockets John
John Sprockets - Responder
Top notch how to document! Commentary and photos are excellent. Good job! And thank you very much
M Robarton - Responder
Where are y’all finding the motor? Please advise… this looks doable! Thank you for your assistance. Michelle
Michelle Paredes - Responder
Came here to say the same, where do you get the new motor??
Jason Courtney - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 53
Ao todo: 9,255
