Ir para o conteúdo principal
Heating Element Contacts
O que você precisa
  1. Heating Element Contacts, Heating Element Contacts: passo 1, imagem 1 %32 Heating Element Contacts, Heating Element Contacts: passo 1, imagem 2 %32 Heating Element Contacts, Heating Element Contacts: passo 1, imagem 3 %32
    • Before you begin, be sure to unplug your coffee maker.
    • Flip the coffee maker over so the bottom is facing upwards.
    • Use the T10 Torx screwdriver to remove all four 17 mm-long screws.
    • Lift the bottom cover off the bottom of the coffee maker.
    Pergunte ao FixBot
    Comentar
  2. Heating Element Contacts: passo 2, imagem 1 %32 Heating Element Contacts: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    FixHub Smart Soldering Iron
    $79.95
    • If heating element contacts are disconnected, use soldering iron with soldering wire to re-bond the contacts.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UW Stout, Team S8-G1, Ogden Spring 2018 Membro de UW Stout, Team S8-G1, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G1
4 Membros
Autoria de 15 guias
1Comentário do guia
Cuisinart Drip Coffee Maker:
Model CBC-6500PCC
In use:
Less than one year.
Problem:
Not heating
Cause:
Blown thermal fuse (240C) connected in series with one side of heating element (there are two, each one connected in series and attached directly to each side of the heating element.) Not replaceable by itself.
Remedy:
Replacement under warranty or purchase a used one at Goodwill, Salvation Army, Value Village, local online personal seller, etc.
brian.steven.richmond - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 62
Ao todo: 4,028
