Ir para o conteúdo principal
Hamilton Beach Power Cord Replacement
O que você precisa
  1. Hamilton Beach  Power Cord Replacement, Motor: passo 1, imagem 1 %32 Hamilton Beach  Power Cord Replacement, Motor: passo 1, imagem 2 %32 Hamilton Beach  Power Cord Replacement, Motor: passo 1, imagem 3 %32
    • Flip the handle on its side. Remove five 3.8 mm Philips #2 screws shown and set aside them aside.
    Pergunte ao FixBot
    Comentar
  2. Hamilton Beach  Power Cord Replacement: passo 2, imagem 1 %32 Hamilton Beach  Power Cord Replacement: passo 2, imagem 2 %32 Hamilton Beach  Power Cord Replacement: passo 2, imagem 3 %32
    • Remove the four 8.6 mm Philips #2 screws securing the motor mount and place them aside.
    Pergunte ao FixBot
    Comentar
  3. Hamilton Beach  Power Cord Replacement: passo 3, imagem 1 %32 Hamilton Beach  Power Cord Replacement: passo 3, imagem 2 %32 Hamilton Beach  Power Cord Replacement: passo 3, imagem 3 %32
    • Carefully pull the motor block out of the case.
    • Collect the two spring located on top of the white beater gears. The springs are held in place with compression, and may fall into the case when the motor is moved.
    • Handle the wires with care to ensure you do not break any of them.
    Pergunte ao FixBot
    Comentar
  4. Hamilton Beach  Power Cord Replacement: passo 4, imagem 1 %32 Hamilton Beach  Power Cord Replacement: passo 4, imagem 2 %32 Hamilton Beach  Power Cord Replacement: passo 4, imagem 3 %32
    • Desolder the six wires connected to the motor using this guide.
    • Make sure to note colors when you disconnect them and remember where to reconnect them later.
    Pergunte ao FixBot
    Comentar
  5. Hamilton Beach  Power Cord Replacement: passo 5, imagem 1 %32 Hamilton Beach  Power Cord Replacement: passo 5, imagem 2 %32
    • Once disconnected, the motor will slide out easily.
    Pergunte ao FixBot
    Comentar
  6. Hamilton Beach  Power Cord Replacement, Speed Level: passo 6, imagem 1 %32 Hamilton Beach  Power Cord Replacement, Speed Level: passo 6, imagem 2 %32 Hamilton Beach  Power Cord Replacement, Speed Level: passo 6, imagem 3 %32
    • Remove the seven 5.6 mm Philips #2 screws that attach the motor casing to the mixer handle and set them aside.
    Pergunte ao FixBot
    Comentar
  7. Hamilton Beach  Power Cord Replacement: passo 7, imagem 1 %32 Hamilton Beach  Power Cord Replacement: passo 7, imagem 2 %32 Hamilton Beach  Power Cord Replacement: passo 7, imagem 3 %32
    • Use a plastic opening tool to take off the handle's cap by loosening both ends and then sliding the tool to the middle of the handle.
    Pergunte ao FixBot
    Comentar
  8. Hamilton Beach  Power Cord Replacement: passo 8, imagem 1 %32 Hamilton Beach  Power Cord Replacement: passo 8, imagem 2 %32
    • Remove the handle's cap carefully.
    • Watch out for the quick burst button, it likes to run away.
    Pergunte ao FixBot
    Comentar
  9. Hamilton Beach  Power Cord Replacement: passo 9, imagem 1 %32 Hamilton Beach  Power Cord Replacement: passo 9, imagem 2 %32 Hamilton Beach  Power Cord Replacement: passo 9, imagem 3 %32
    • Slide the speed switch forward and lift upward off of the handle.
    Pergunte ao FixBot
    Comentar
  10. Hamilton Beach  Power Cord Replacement: passo 10, imagem 1 %32 Hamilton Beach  Power Cord Replacement: passo 10, imagem 2 %32
    • Remove speed level from the inside of the case by applying light pressure toward you.
    • Do not pull on the wires to remove the speed level.
    Pergunte ao FixBot
    Comentar
  11. Hamilton Beach  Power Cord Replacement: passo 11, imagem 1 %32 Hamilton Beach  Power Cord Replacement: passo 11, imagem 2 %32 Hamilton Beach  Power Cord Replacement: passo 11, imagem 3 %32
    • Remove the beater release button from speed level by removing the two 1.3 mm Philips #2 screws.
    • Replace the speed level assembly.
    Pergunte ao FixBot
    Comentar
  12. Hamilton Beach  Power Cord Replacement, Power Cord: passo 12, imagem 1 %32 Hamilton Beach  Power Cord Replacement, Power Cord: passo 12, imagem 2 %32 Hamilton Beach  Power Cord Replacement, Power Cord: passo 12, imagem 3 %32
    • Liftback end of the handle up from motor casing.
    • Pull back to detach fully from the stainless steel.
    Pergunte ao FixBot
    Comentar
  13. Hamilton Beach  Power Cord Replacement: passo 13, imagem 1 %32 Hamilton Beach  Power Cord Replacement: passo 13, imagem 2 %32 Hamilton Beach  Power Cord Replacement: passo 13, imagem 3 %32
    • Remove the three 7.8 mm Philips #2 screws holding the power cord in place.
    Pergunte ao FixBot
    Comentar
  14. Hamilton Beach  Power Cord Replacement: passo 14, imagem 1 %32 Hamilton Beach  Power Cord Replacement: passo 14, imagem 2 %32 Hamilton Beach  Power Cord Replacement: passo 14, imagem 3 %32
    • Cut zip tie holding the power cable together using handheld wire cutters.
    Pergunte ao FixBot
    Comentar
  15. Hamilton Beach  Power Cord Replacement: passo 15, imagem 1 %32 Hamilton Beach  Power Cord Replacement: passo 15, imagem 2 %32 Hamilton Beach  Power Cord Replacement: passo 15, imagem 3 %32
    • Untie the black lead's knot.
    • Cut both wires with handheld wire cutters.
    • Follow this guide to solder new power cord wires in.
    Pergunte ao FixBot
    Comentar
Conclusão
Gwen Davis
Membro desde: 03/24/16
519 Reputação
Autoria de 5 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 40
Ao todo: 2,000
