Ir para o conteúdo principal
Hair Dryer Power Supply Replacement
O que você precisa
    1. Hair Dryer Power Supply Replacement, Nozzle: passo 1, imagem 1 %32 Hair Dryer Power Supply Replacement, Nozzle: passo 1, imagem 2 %32
      • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
      • If nozzle is not attached, skip to next step.
      Pergunte ao FixBot
      Comentar
    1. Hair Dryer Power Supply Replacement, Grating: passo 2, imagem 1 %32
      • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
      • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Hair Dryer Power Supply Replacement: passo 3, imagem 1 %32
      • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
      Pergunte ao FixBot
      Comentar
    3. Hair Dryer Power Supply Replacement: passo 4, imagem 1 %32
      • Separate the hair dryer grating into the three pieces seen in the image.
      Pergunte ao FixBot
      Comentar
    1. Hair Dryer Power Supply Replacement, Power Supply: passo 5, imagem 1 %32
      • Locate the screws on the handle and remove with a Phillips screwdriver
      Pergunte ao FixBot
      Comentar
    2. Hair Dryer Power Supply Replacement: passo 6, imagem 1 %32
      • Carefully separate the plastic case with Plastic Opening Tools
      Pergunte ao FixBot
      Comentar
    3. Hair Dryer Power Supply Replacement: passo 7, imagem 1 %32
      • Your hairdryer should now be disassembled and you should easily be able to see the fan, motor, heating element cover, and internal wiring.
      Pergunte ao FixBot
      Comentar
    4. Hair Dryer Power Supply Replacement: passo 8, imagem 1 %32
      • After disassembly and isolating the button switchboard, locate the small component that is directly connected to the power cord. Desolder the wires using a desoldering wick and a soldering iron. Refer to the soldering page below.
      • Soldering Skills
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Mitch
Membro desde: 10/04/12
37 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 24-29, Regan Fall 2012 Membro de Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
5 Membros
Autoria de 17 guias
1Comentário do guia
Will this work on damaged cord near the end of hair dryer? The hair dryer is great shape just the cord that needed to be stripped to get rid of damaged part then cut then wired again.
Donna Baillod - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 19
Últimos 30 dias: 76
Ao todo: 23,183
