Ir para o conteúdo principal
Hair Dryer Heating Element Replacement
O que você precisa
  1. Hair Dryer Heating Element Replacement, Nozzle: passo 1, imagem 1 %32 Hair Dryer Heating Element Replacement, Nozzle: passo 1, imagem 2 %32
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
  2. Hair Dryer Heating Element Replacement, Grating: passo 2, imagem 1 %32
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
  3. Hair Dryer Heating Element Replacement: passo 3, imagem 1 %32
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
  4. Hair Dryer Heating Element Replacement: passo 4, imagem 1 %32
    • Separate the hair dryer grating into the three pieces seen in the image.
  5. Hair Dryer Heating Element Replacement, Heating Element: passo 5, imagem 1 %32
    • Using the Phillips #1 screwdriver remove the two screws holding the handle of the dryer together.
  6. Hair Dryer Heating Element Replacement: passo 6, imagem 1 %32 Hair Dryer Heating Element Replacement: passo 6, imagem 2 %32
    • Carefully separate the plastic casing using a spudger. Your hairdryer should now be disassembled into two large halves.
    • This can also be done with your hands if you twist the sides of the hair dryer slightly in opposite directions.
  7. Hair Dryer Heating Element Replacement: passo 7, imagem 1 %32
    • Remove the heat-element housing by sliding it off of the dryer in the direction away from the handle.
    • Make sure the heating element is facing up so that removal is easier. If there is a casing, slightly twist as needed.
  8. Hair Dryer Heating Element Replacement: passo 8, imagem 1 %32
    • Isolate the heating element.
    • Use a desoldering wick and soldering iron to desolder the wires.
    • Refer to this soldering page for more information on soldering.
    • You will need to be careful with these wires. Do not cut or yank the wires; this may cause further issues with your hair dryer.
Conclusão
To reassemble your device, follow these instructions in reverse order. Make sure wiring is enclosed in the body of the hair dryer, and the heating element casing is attached properly before screwing it closed.
8 outras pessoas executaram este guia.
Mitch
Membro desde: 10/04/12
34 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 24-29, Regan Fall 2012 Membro de Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 30
Últimos 30 dias: 183
Duração total: 42,851
