Ir para o conteúdo principal
Haiboxing 18859 Receiver Replacement
O que você precisa
  1. Haiboxing 18859 Receiver Replacement, Battery: passo 1, imagem 1 %32 Haiboxing 18859 Receiver Replacement, Battery: passo 1, imagem 2 %32 Haiboxing 18859 Receiver Replacement, Battery: passo 1, imagem 3 %32
    • Remove the 4 clips holding down the hard plastic shell of the RC car. Do this by pinching them with your thumb and index finger and pulling away.
    Pergunte ao FixBot
    Comentar
  2. Haiboxing 18859 Receiver Replacement: passo 2, imagem 1 %32
    • Lift the hard plastic shell off of the RC car.
    Pergunte ao FixBot
    Comentar
  3. Haiboxing 18859 Receiver Replacement: passo 3, imagem 1 %32 Haiboxing 18859 Receiver Replacement: passo 3, imagem 2 %32 Haiboxing 18859 Receiver Replacement: passo 3, imagem 3 %32
    • Disconnect the Lego-style battery connector by gripping either side and pulling them away from each other, slowly and consistently.
    Pergunte ao FixBot
    Comentar
  4. Haiboxing 18859 Receiver Replacement: passo 4, imagem 1 %32 Haiboxing 18859 Receiver Replacement: passo 4, imagem 2 %32 Haiboxing 18859 Receiver Replacement: passo 4, imagem 3 %32
    • Unfasten the Velcro strap that secures the battery.
    Pergunte ao FixBot
    Comentar
  5. Haiboxing 18859 Receiver Replacement: passo 5, imagem 1 %32 Haiboxing 18859 Receiver Replacement: passo 5, imagem 2 %32
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  6. Haiboxing 18859 Receiver Replacement, Receiver: passo 6, imagem 1 %32 Haiboxing 18859 Receiver Replacement, Receiver: passo 6, imagem 2 %32 Haiboxing 18859 Receiver Replacement, Receiver: passo 6, imagem 3 %32
    • Disonnect all connectors attached to the red, plastic receiver.
    Pergunte ao FixBot
    Comentar
  7. Haiboxing 18859 Receiver Replacement: passo 7, imagem 1 %32
    • Remove the 8 mm Phillips #0 screw holding the front corner of the receiver down.
    • Remove the front corner piece.
    Pergunte ao FixBot
    Comentar
  8. Haiboxing 18859 Receiver Replacement: passo 8, imagem 1 %32 Haiboxing 18859 Receiver Replacement: passo 8, imagem 2 %32 Haiboxing 18859 Receiver Replacement: passo 8, imagem 3 %32
    • Remove the receiver.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Kevin Hillmann
Membro desde: 03/21/25
258 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 41
Ao todo: 559
