Introdução
Follow this guide to replace the two batteries in your HTC Vive XR Elite battery cradle.
If either battery is swollen, take appropriate precautions.
O que você precisa
Press the release button on the right battery cradle temple slot.
Pull the battery cradle away from the right temple slot to disconnect it.
Insert a long edge of an opening pick in the gap between the two halves of the battery cradle, near the USB-C cable.
Slide the opening pick along the top edge of battery cradle to release its plastic clips.
Slide the opening pick along the bottom edge of battery cradle to release its plastic clips.
Pull apart the two halves of the battery cradle to completely separate them.
Ferramenta utilizada nesse passo:FixMat$36.95
Use a T5 Torx screwdriver to remove the nine screws securing the inner plastic frame:
Five 11.8 mm-long screws
Three 5.6 mm-long screws
One 5.6 mm-long screw
Remove the inner plastic frame, making sure to thread the graphite thermal tape through it.
Use a T5 Torx screwdriver to remove the two 5.6 mm-long screws securing the headstrap clips.
Use the flat end of a spudger to push the left and right battery cell connectors out of their respective sockets.
Use the point of a spudger to flip up the locking flap on the power LED ZIF connector.
Use tweezers or your fingers to disconnect the power LED cable.
Pull the black tab straight up on the USB-C power cable to disconnect it.
Use tweezers or your fingers to peel the conductive tape away from the front metal battery enclosure.
Use a T5 Torx screwdriver to remove the four 4.1 mm-long screws securing the battery board.
Use a T5 Torx screwdriver to remove the three screws securing the front metal battery enclosure:
Two 11.8 mm-long screws
One 4.8 mm-long screw
Stand the battery cradle upright so the battery cells can fold flat on your work surface.
Peel off the graphite thermal tape covering the right battery cell.
Remove the right battery cell.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
