Ir para o conteúdo principal
HTC Trophy Power Button Replacement
O que você precisa
  1. HTC Trophy Power Button Replacement, Battery: passo 1, imagem 1 %32 HTC Trophy Power Button Replacement, Battery: passo 1, imagem 2 %32 HTC Trophy Power Button Replacement, Battery: passo 1, imagem 3 %32
    • Power off the phone before starting.
    • Remove the back panel by inserting the IFixIt opening tool into gap at the top of the rear and prying upward.
    Pergunte ao FixBot
    Comentar
  2. HTC Trophy Power Button Replacement: passo 2, imagem 1 %32 HTC Trophy Power Button Replacement: passo 2, imagem 2 %32 HTC Trophy Power Button Replacement: passo 2, imagem 3 %32
    • Remove the battery by inserting the IFixIt opening tool into the small gap between the battery and the surrounding plastic.
    • Apply a small force towards the bottom of the phone and lift upwards.
    • Be careful not to puncture the battery.
    Pergunte ao FixBot
    Comentar
  3. HTC Trophy Power Button Replacement, Display Assembly: passo 3, imagem 1 %32 HTC Trophy Power Button Replacement, Display Assembly: passo 3, imagem 2 %32 HTC Trophy Power Button Replacement, Display Assembly: passo 3, imagem 3 %32
    • Remove the 5 screws holding the two phone halves together.
    • Three 4mm long T5 Torx screws.
    • Press a T5 Torx screwdriver into the void sticker and remove the 4mm long T5 Torx screw.
    • One 4mm long Philips #000 screw.
    • Remove the installed SIM card if one is present.
    Pergunte ao FixBot
    Comentar
  4. HTC Trophy Power Button Replacement: passo 4, imagem 1 %32 HTC Trophy Power Button Replacement: passo 4, imagem 2 %32 HTC Trophy Power Button Replacement: passo 4, imagem 3 %32
    • Insert the IFixIt opening tool into the seem of the plastic around the edge of the phone and pry the two halves apart.
    • There are small plastic clips holding the phone together. Slide the opening tool around the edge until it clicks apart to avoid damage.
    • The volume button will fall out when the phone is opened.
    • The black sticker beneath the battery will rip once the phone is separated.
    Pergunte ao FixBot
    Comentar
  5. HTC Trophy Power Button Replacement: passo 5, imagem 1 %32 HTC Trophy Power Button Replacement: passo 5, imagem 2 %32 HTC Trophy Power Button Replacement: passo 5, imagem 3 %32
    • Remove the three screws holding the mother board to the display assembly.
    • One 2mm long Philips #000 screw.
    • Two 4mm long T5 Torx screws in the holes of the plastic.
    Pergunte ao FixBot
    Comentar
  6. HTC Trophy Power Button Replacement: passo 6, imagem 1 %32 HTC Trophy Power Button Replacement: passo 6, imagem 2 %32 HTC Trophy Power Button Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the black tape cover the ribbon cable connectors with tweezers.
    • Disconnect the ribbon cables from the connectors.
    • Ribbon cables are extremely fragile.
    Pergunte ao FixBot
    Comentar
  7. HTC Trophy Power Button Replacement: passo 7, imagem 1 %32 HTC Trophy Power Button Replacement: passo 7, imagem 2 %32
    • Remove power button from the top of the phone with tweezers.
    Pergunte ao FixBot
    Comentar
  8. HTC Trophy Power Button Replacement: passo 8, imagem 1 %32 HTC Trophy Power Button Replacement: passo 8, imagem 2 %32 HTC Trophy Power Button Replacement: passo 8, imagem 3 %32
    • Use the iFixit opening tool to separate the motherboard from the display assembly.
    Pergunte ao FixBot
    Comentar
  9. HTC Trophy Power Button Replacement, Motherboard: passo 9, imagem 1 %32 HTC Trophy Power Button Replacement, Motherboard: passo 9, imagem 2 %32 HTC Trophy Power Button Replacement, Motherboard: passo 9, imagem 3 %32
    • Remove the plastic piece off of the motherboard.
    • Put pressure outwards to release these clips with the iFixit opening tool and you fingers.
    Pergunte ao FixBot
    Comentar
  10. HTC Trophy Power Button Replacement, Power Button: passo 10, imagem 1 %32 HTC Trophy Power Button Replacement, Power Button: passo 10, imagem 2 %32
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 24
Ao todo: 345
