Ir para o conteúdo principal
HTC Touch Pro 2 Logic Board Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. HTC Touch Pro 2 Logic Board Replacement, Battery: passo 1, imagem 1 %32 HTC Touch Pro 2 Logic Board Replacement, Battery: passo 1, imagem 2 %32 HTC Touch Pro 2 Logic Board Replacement, Battery: passo 1, imagem 3 %32
    • Apply pressure and slide upward to remove back cover.
    • Lift the back cover up away from the phone.
    Pergunte ao FixBot
    Comentar
  2. HTC Touch Pro 2 Logic Board Replacement: passo 2, imagem 1 %32 HTC Touch Pro 2 Logic Board Replacement: passo 2, imagem 2 %32
    • Lift battery upward on the upper right-hand side to remove it.
    • Check the battery to make sure there's no bent corners.
    Pergunte ao FixBot
    Comentar
  3. HTC Touch Pro 2 Logic Board Replacement, Housing: passo 3, imagem 1 %32 HTC Touch Pro 2 Logic Board Replacement, Housing: passo 3, imagem 2 %32
    • Using a T5 screwdriver, remove the four screws in corners as shown.
    • Lift the top portion of the rear case.
    • Potential for device damage: There is a ribbon attached on the back of this part that requires caution to remove.
    Pergunte ao FixBot
    Comentar
  4. HTC Touch Pro 2 Logic Board Replacement: passo 4, imagem 1 %32 HTC Touch Pro 2 Logic Board Replacement: passo 4, imagem 2 %32 HTC Touch Pro 2 Logic Board Replacement: passo 4, imagem 3 %32
    • Using an IfixIt Plastic Tool, detach the plastic casing from the keyboard. This may require some force.
    • Using a spudger or other thin tool, carefully pry up ZIF connectors as shown. This will allow the black ribbons to detach from the keyboard.
    • Slide the two parts away from each other so that the black ribbons slide through the slots and you will now have housing into two parts.
    Pergunte ao FixBot
    Comentar
Conclusão
Melinda Phan
Membro desde: 04/17/11
438 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 9-64, Walters Spring 2011 Membro de Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 32
Ao todo: 4,940
