Ir para o conteúdo principal
HTC Desire 826 Screen Replacement
O que você precisa
  1. HTC Desire 826 Screen Replacement, Battery: passo 1, imagem 1 %32 HTC Desire 826 Screen Replacement, Battery: passo 1, imagem 2 %32 HTC Desire 826 Screen Replacement, Battery: passo 1, imagem 3 %32
    • Find a seam in the back of the device.
    • Insert the plastic spudger into the seam and pry off the back panel.
    • There will be glue, so keep prying until it comes off or you may need to heat up the edges of the device to loosen the adhesive with the iOpener.
    Pergunte ao FixBot
    Comentar
  2. HTC Desire 826 Screen Replacement: passo 2, imagem 1 %32 HTC Desire 826 Screen Replacement: passo 2, imagem 2 %32 HTC Desire 826 Screen Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the 4.0 mm screw above the battery with a T5 Torx screwdriver.
    • Remove the metal bracket with the tweezers.
    Pergunte ao FixBot
    Comentar
  3. HTC Desire 826 Screen Replacement: passo 3, imagem 1 %32
    • Disconnect the battery cable from the motherboard with the tweezers.
    Pergunte ao FixBot
    Comentar
  4. HTC Desire 826 Screen Replacement: passo 4, imagem 1 %32 HTC Desire 826 Screen Replacement: passo 4, imagem 2 %32
    • Lift the battery with a plastic spudger and remove it from the device.
    Pergunte ao FixBot
    Comentar
  5. HTC Desire 826 Screen Replacement, Screen: passo 5, imagem 1 %32 HTC Desire 826 Screen Replacement, Screen: passo 5, imagem 2 %32
    • Remove the two 4.0 mm screws attaching the bottom plastic panel using a T5 screwdriver.
    • Remove the black plastic cover using a plastic spudger
    Pergunte ao FixBot
    Comentar
  6. HTC Desire 826 Screen Replacement: passo 6, imagem 1 %32
    • Use tweezers to pry the wire up from the battery bed
    • Detach the ribbon cable by pulling with the tweezers where circled in blue
    • Flip the phone over so the screen side is facing up for the next step
    Pergunte ao FixBot
    Comentar
  7. HTC Desire 826 Screen Replacement: passo 7, imagem 1 %32 HTC Desire 826 Screen Replacement: passo 7, imagem 2 %32
    • Use the metal spudger to pry up the plastic cover pieces from the front of the phone
    Pergunte ao FixBot
    Comentar
  8. HTC Desire 826 Screen Replacement: passo 8, imagem 1 %32 HTC Desire 826 Screen Replacement: passo 8, imagem 2 %32
    • Pry up the edges of the screen using the metal spudger
    • Then use the suction cup to remove the screen from your device
    • There will likely be glue holding your screen in place, so keep prying but be cautious not to break the screen. You may want to use the iOpener to loosen the adhesive prior to removal.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
1Comentário do guia
Après avoir fait le démontage de l'écran , le digital est devenu très dur et ne réagi pas automatiquement au toucher . Que dois-je faire ?
Japhet piergy Bassa - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 700
