Ir para o conteúdo principal
HP pavilion 15-cc561st Speakers Replacement
O que você precisa
  1. HP pavilion 15-cc561st Speakers Replacement, Bottom Cover: passo 1, imagem 1 %32 HP pavilion 15-cc561st Speakers Replacement, Bottom Cover: passo 1, imagem 2 %32 HP pavilion 15-cc561st Speakers Replacement, Bottom Cover: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Before you begin to remove the bottom cover, shut down the computer. Disconnect all external devices and unplug the AC adapter. Flip the laptop upside down.
    • Use a Phillips #0 screwdriver to remove five screws from the bottom cover:
    • Two 5.6 mm screws
    • Each of these screws are beneath the two rubber feet on the rear side of the laptop (near the display hinges). You do not have to completely remove the rubber feet to remove the screws; simply peel the top of the feet to reveal the screws.
    • Three 5.8 mm screws
    • Throughout this repair, keep track of each screw size and location to avoid damaging your device.
  2. HP pavilion 15-cc561st Speakers Replacement: passo 2, imagem 1 %32 HP pavilion 15-cc561st Speakers Replacement: passo 2, imagem 2 %32
    • Insert an opening tool into the space between the display hinges and the bottom cover.
    • Firmly push the opening tool upwards to separate the bottom cover from these areas.
  3. HP pavilion 15-cc561st Speakers Replacement: passo 3, imagem 1 %32 HP pavilion 15-cc561st Speakers Replacement: passo 3, imagem 2 %32 HP pavilion 15-cc561st Speakers Replacement: passo 3, imagem 3 %32
    • Insert your opening tool and firmly push the tool upwards along the rear edge.
  4. HP pavilion 15-cc561st Speakers Replacement: passo 4, imagem 1 %32 HP pavilion 15-cc561st Speakers Replacement: passo 4, imagem 2 %32 HP pavilion 15-cc561st Speakers Replacement: passo 4, imagem 3 %32
    • Use the opening tool again on the left and right sides.
    • Start prying at the areas closer to the rear of the laptop (near the display hinges) before moving towards areas that are closer to the front of the laptop (away from the display hinges).
    • Pry a little bit on the left side, then pry a little bit on the right side before prying more on the left side again. Working on both sides in this incremental fashion is easier than completely prying one side before starting the other side.
  5. HP pavilion 15-cc561st Speakers Replacement: passo 5, imagem 1 %32
    • Lift the bottom cover upwards to remove it.
  6. HP pavilion 15-cc561st Speakers Replacement, Battery: passo 6, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the five 5.7 mm screws that secure the battery.
  7. HP pavilion 15-cc561st Speakers Replacement: passo 7, imagem 1 %32 HP pavilion 15-cc561st Speakers Replacement: passo 7, imagem 2 %32 HP pavilion 15-cc561st Speakers Replacement: passo 7, imagem 3 %32
    • Pull the battery towards the front edge of the laptop to disconnect it from the 8-pin battery connector.
    • Lift the disconnected battery upwards to remove it.
    • Calibrate a newly-installed battery to help your laptop get an accurate battery percentage reading.
  8. HP pavilion 15-cc561st Speakers Replacement, WLAN Module: passo 8, imagem 1 %32
    • Disconnect the WLAN antenna cables from the terminals on the WLAN module:
    • Cable labeled "1/AUX" which connects to the "Aux" terminal
    • Cable labeled "2/MAIN" which connects to the "Main" terminal
  9. HP pavilion 15-cc561st Speakers Replacement: passo 9, imagem 1 %32 HP pavilion 15-cc561st Speakers Replacement: passo 9, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the 3.0 mm screw that secures the WLAN module.
    • Removing this screw will cause the WLAN module to tilt up.
  10. HP pavilion 15-cc561st Speakers Replacement: passo 10, imagem 1 %32
    • Pull the WLAN module away from the slot at the angle it rises from.
    • Line up the notches on a new memory module with the slot. These notches are designed to prevent incorrect insertion.
  11. HP pavilion 15-cc561st Speakers Replacement, Fan: passo 11, imagem 1 %32
    • Disconnect the fan cable from the motherboard.
    • Handle the cable by the connector. Avoid pulling on the cables themselves to avoid damaging the cables.
  12. HP pavilion 15-cc561st Speakers Replacement: passo 12, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the three 5.8 mm screws that secure the fan.
  13. HP pavilion 15-cc561st Speakers Replacement: passo 13, imagem 1 %32
    • Lift the fan upwards to remove it.
  14. HP pavilion 15-cc561st Speakers Replacement, Heat Sink: passo 14, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the four 3.0 mm screws that secure the heat sink.
  15. HP pavilion 15-cc561st Speakers Replacement: passo 15, imagem 1 %32 HP pavilion 15-cc561st Speakers Replacement: passo 15, imagem 2 %32 HP pavilion 15-cc561st Speakers Replacement: passo 15, imagem 3 %32
    • Lift the heat sink upwards to remove it.
    • Thermal paste must be thoroughly cleaned from the surfaces of both the heat sink and the processor each time the heat sink is removed. Apply new thermal paste before reinstalling the heat sink.
  16. HP pavilion 15-cc561st Speakers Replacement, Speakers: passo 16, imagem 1 %32 HP pavilion 15-cc561st Speakers Replacement, Speakers: passo 16, imagem 2 %32
    • Remove the bundled cable connector from the terminal by pulling it horizontally out of its socket.
  17. HP pavilion 15-cc561st Speakers Replacement: passo 17, imagem 1 %32 HP pavilion 15-cc561st Speakers Replacement: passo 17, imagem 2 %32
    • Remove the ZIF ribbon cable by pulling it gently.
  18. HP pavilion 15-cc561st Speakers Replacement: passo 18, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the 5.8 mm screw on the right speaker.
  19. HP pavilion 15-cc561st Speakers Replacement: passo 19, imagem 1 %32 HP pavilion 15-cc561st Speakers Replacement: passo 19, imagem 2 %32
    • Remove 3 silver 2.95 mm screws with a Phillips #0 screwdriver
    • Remove the 4 black 5.65 mm screws with a Phillips #0 screwdriver.
  20. HP pavilion 15-cc561st Speakers Replacement: passo 20, imagem 1 %32
    • Remove the power supply female connector by lifting it up via the black stick spudger.
  21. HP pavilion 15-cc561st Speakers Replacement: passo 21, imagem 1 %32 HP pavilion 15-cc561st Speakers Replacement: passo 21, imagem 2 %32 HP pavilion 15-cc561st Speakers Replacement: passo 21, imagem 3 %32
    • To remove the ZIF ribbons, pull up on the tab and gently pull away from the connector. Repeat for all 6 ZIF ribbons shown.
  22. HP pavilion 15-cc561st Speakers Replacement: passo 22, imagem 1 %32
    • Remove the motherboard
  23. HP pavilion 15-cc561st Speakers Replacement: passo 23, imagem 1 %32
    • Unhook the wires of the speaker from the retaining tabs.
    • Remove the speakers.
Conclusão
Bhargav Patel
Membro desde: 03/27/23
385 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 1-1, Harley Spring 2023 Membro de IUPUI, Team 1-1, Harley Spring 2023
IUPUI-HARLEY-S23S1G1
3 Membros
Autoria de 3 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 311
