Ir para o conteúdo principal
HP ZBook 15 Screen Replacement
O que você precisa
  1. HP ZBook 15 Screen Replacement, Battery: passo 1, imagem 1 %32 HP ZBook 15 Screen Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
    Pergunte ao FixBot
    Comentar
  2. HP ZBook 15 Screen Replacement, Screen: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Orient the laptop keyboard-side up.
    • Use tweezers to remove the adhesive covers for the screws.
    Pergunte ao FixBot
    Comentar
  3. HP ZBook 15 Screen Replacement: passo 3, imagem 1 %32
    • Remove the two 6mm screws with a Phillips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  4. HP ZBook 15 Screen Replacement: passo 4, imagem 1 %32 HP ZBook 15 Screen Replacement: passo 4, imagem 2 %32
    • Pull the bezel away from the screen.
    • Be sure to go one edge at a time! Do not pull hard on the corners as it may crack the bezel.
    Pergunte ao FixBot
    Comentar
  5. HP ZBook 15 Screen Replacement: passo 5, imagem 1 %32
    • Remove the four 3mm screws with a Phillips #0 screwdriver near the corners of the screen to remove the display.
    • Be careful not to confuse any screws. They are close together and you may remove the back cover instead of the display.
    Pergunte ao FixBot
    Comentar
  6. HP ZBook 15 Screen Replacement: passo 6, imagem 1 %32 HP ZBook 15 Screen Replacement: passo 6, imagem 2 %32
    • Do not peel the tape from the side closest to the bottom of the screen panel! This may rip out the connector's wires.
    • Gently lower the screen and lay it face down on the keyboard.
    • Lift the corners of the tape closest to the top of the screen and peel toward the center carefully.
    • Slowly pull the tape away from the sides.
    • Lift the tape and disconnect the screen connector.
    • You can leave the tape stuck to the cable connector and still be able to remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
9 outras pessoas executaram este guia.
Grant Terris
Membro desde: 01/30/15
2.888 Reputação
Autoria de 12 guias
Equipe
Cal Poly, Team 8-43, Amido Winter 2015 Membro de Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 Membros
Autoria de 19 guias
3Comentários do guia
Worked great! Only caution that I would add is that on one of the machines I took apart, the adhesive strip behind the bottom of the bezel stuck to the bezel and not the circuit board behind. I had to carefully slide my finger between the adhesive strip and the bezel to separate them. Once the bezel was removed, I was able to stick the adhesive back down. I think this laptop may have been exposed to some sort of liquid, so this may not be a common issue.
dwakefield - Responder Compartilhar
My ZBook 15u g5 does not have any adhesive covers around the screen. How do I replace?
H B - Responder Compartilhar
Hello can i replace my hd screen with another fhd one?
Mohand Almohands - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 22
Últimos 30 dias: 102
Ao todo: 18,361
