Ir para o conteúdo principal
HP Z2 Mini G3 Real-Time Clock Battery Replacement
  1. HP Z2 Mini G3 Real-Time Clock Battery Replacement, Access Panel: passo 1, imagem 1 %32
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
    Pergunte ao FixBot
    Comentar
  2. HP Z2 Mini G3 Real-Time Clock Battery Replacement: passo 2, imagem 1 %32 HP Z2 Mini G3 Real-Time Clock Battery Replacement: passo 2, imagem 2 %32
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
    Pergunte ao FixBot
    Comentar
  3. HP Z2 Mini G3 Real-Time Clock Battery Replacement: passo 3, imagem 1 %32 HP Z2 Mini G3 Real-Time Clock Battery Replacement: passo 3, imagem 2 %32
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
    Pergunte ao FixBot
    Comentar
  4. HP Z2 Mini G3 Real-Time Clock Battery Replacement, Real-Time Clock Battery: passo 4, imagem 1 %32
    • Rotate the device so the back-side is facing you and locate the RTC battery.
    • You may have to swing the CPU Fan and GPU Fan upwards to fully access the Real-Time Clock (RTC) Battery.
    Pergunte ao FixBot
    Comentar
  5. HP Z2 Mini G3 Real-Time Clock Battery Replacement: passo 5, imagem 1 %32
    • Press the battery down and away to free it of the latches.
    • Use your hand to grab and lift the battery out of the socket.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 21
Últimos 30 dias: 122
Ao todo: 4,914
