Ir para o conteúdo principal
HP Z2 Mini G3 CPU Fan Replacement
  1. HP Z2 Mini G3 CPU Fan Replacement, Access Panel: passo 1, imagem 1 %32
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
    Pergunte ao FixBot
    Comentar
  2. HP Z2 Mini G3 CPU Fan Replacement: passo 2, imagem 1 %32 HP Z2 Mini G3 CPU Fan Replacement: passo 2, imagem 2 %32
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
    Pergunte ao FixBot
    Comentar
  3. HP Z2 Mini G3 CPU Fan Replacement: passo 3, imagem 1 %32 HP Z2 Mini G3 CPU Fan Replacement: passo 3, imagem 2 %32
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
    Pergunte ao FixBot
    Comentar
  4. HP Z2 Mini G3 CPU Fan Replacement, CPU Fan: passo 4, imagem 1 %32
    • Rotate the device so the front side is facing you (the side with the power button) and locate the CPU fan.
    Pergunte ao FixBot
    Comentar
  5. HP Z2 Mini G3 CPU Fan Replacement: passo 5, imagem 1 %32
    • Swing the fan upward, to a 90-degree angle.
    Pergunte ao FixBot
    Comentar
  6. HP Z2 Mini G3 CPU Fan Replacement: passo 6, imagem 1 %32 HP Z2 Mini G3 CPU Fan Replacement: passo 6, imagem 2 %32
    • Carefully disconnect the CPU fan by pulling out the wires from the motherboard.
    Pergunte ao FixBot
    Comentar
  7. HP Z2 Mini G3 CPU Fan Replacement: passo 7, imagem 1 %32
    • Swing the fan back down and carefully unhook the CPU fan notches by pulling each tab away from the heat sink holes.
    Pergunte ao FixBot
    Comentar
  8. HP Z2 Mini G3 CPU Fan Replacement: passo 8, imagem 1 %32
    • Swing the fan up again and pull it out.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 59
Ao todo: 2,337
