Ir para o conteúdo principal
HP Stream 8 Speakers Replacement
O que você precisa
    1. HP Stream 8 Speakers Replacement, Midframe: passo 1, imagem 1 %32
      • Use your nail or a spudger to pry the back cover off of the device.
      Pergunte ao FixBot
      Comentar
    2. HP Stream 8 Speakers Replacement: passo 2, imagem 1 %32
      • Slide your finger around the rest of the back cover, lifting it completely off of the device.
      Pergunte ao FixBot
      Comentar
    3. HP Stream 8 Speakers Replacement: passo 3, imagem 1 %32
      • Remove ten Phillips #00 screws from the inside cover.
      Pergunte ao FixBot
      Comentar
    4. HP Stream 8 Speakers Replacement: passo 4, imagem 1 %32
      • Pry up the inside cover the same way as in the first step.
      Pergunte ao FixBot
      Comentar
    1. HP Stream 8 Speakers Replacement, Speakers: passo 5, imagem 1 %32 HP Stream 8 Speakers Replacement, Speakers: passo 5, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Locate the two speakers at the bottom of the device.
      • Remove the two speakers by prying them out using a pair of tweezers.
      • Detach the red and black power wiring from the device and pull the speakers entirely out of the HP Stream 8.
      • Remember where the red and black wiring is connected to the device.
      • The power wires are soldered to the device and will be difficult to detach.
      Pergunte ao FixBot
      Comentar
    2. HP Stream 8 Speakers Replacement: passo 6, imagem 1 %32
      • Grab the two replacement speakers and the soldering iron.
      • Locate where the red and black power wiring previously connected to the device.
      • Attach and re-solder the red and black power wiring.
      • For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Nick Miller
Membro desde: 04/11/16
669 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 34-14, Maness Spring 2016 Membro de Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 33
Ao todo: 642
