Ir para o conteúdo principal
HP Spectre x360 15" (15t-ap000) SSD Replacement
O que você precisa
  1. HP Spectre x360 15" (15t-ap000) SSD Replacement, Unscrew the back cover: passo 1, imagem 1 %32
    • Be sure to completely power off and unplug your laptop before you begin your repair. Make sure the laptop is not in standby, sleep, or hibernation mode.
    • Use a T5 driver to remove the following screws securing the back cover:
    • Six 4 mm-long screws
    • Two 7.8 mm-long screws
  2. HP Spectre x360 15" (15t-ap000) SSD Replacement, Loosen the back cover: passo 2, imagem 1 %32 HP Spectre x360 15" (15t-ap000) SSD Replacement, Loosen the back cover: passo 2, imagem 2 %32
    • Use an opening tool or your fingers to pry up the back cover from the laptop.
    • Plastic clips hold the back cover lightly in place, so you may encounter some resistance.
    • If it feels like there is strong resistance, you may have a model that includes screws under the corner feet. Carefully pry the feet up to make sure they don't have screws.
  3. HP Spectre x360 15" (15t-ap000) SSD Replacement, Remove the back cover: passo 3, imagem 1 %32 HP Spectre x360 15" (15t-ap000) SSD Replacement, Remove the back cover: passo 3, imagem 2 %32
    • Lift and remove the back cover.
    • During reassembly, gently press along the perimeter of the back cover to re-engage the clips.
  4. HP Spectre x360 15" (15t-ap000) SSD Replacement, Disconnect the battery: passo 4, imagem 1 %32 HP Spectre x360 15" (15t-ap000) SSD Replacement, Disconnect the battery: passo 4, imagem 2 %32 HP Spectre x360 15" (15t-ap000) SSD Replacement, Disconnect the battery: passo 4, imagem 3 %32
    • Pry the edges of the battery connector with a spudger to loosen the connector from its motherboard socket.
    • Gently pull the connector parallel to the motherboard to disconnect it.
  5. HP Spectre x360 15" (15t-ap000) SSD Replacement, Remove the SSD: passo 5, imagem 1 %32 HP Spectre x360 15" (15t-ap000) SSD Replacement, Remove the SSD: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use your fingers or tweezers to peel the black plastic strip until you uncover the SSD.
  6. HP Spectre x360 15" (15t-ap000) SSD Replacement: passo 6, imagem 1 %32
    • Use a Phillips screwdriver to remove the 2.8 mm-long screw securing the SSD to the motherboard.
  7. HP Spectre x360 15" (15t-ap000) SSD Replacement: passo 7, imagem 1 %32 HP Spectre x360 15" (15t-ap000) SSD Replacement: passo 7, imagem 2 %32
    • Grasp the SSD edges with your fingers and pull it at a shallow angle parallel to the motherboard.
    • Remove the SSD.
Conclusão
Uma outra pessoa concluiu este guia.
Arthur Shi
Membro desde: 01/03/18
282.999 Reputação
Autoria de 587 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.527 guias
Um comentário
There are several types of M.2 slot supporting different technology, SATA or NVMe, so the first claim in the into is incorrect. Additionally, they are different sizes.
Ed Maher - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 60
Ao todo: 4,209
