Ir para o conteúdo principal
HP ProBook 640 G2 Battery Replacement
O que você precisa
    1. HP ProBook 640 G2 Battery Replacement, Battery: passo 1, imagem 1 %32
      • Flip the laptop so the bottom is facing up.
      • Use a JIS J1 screwdriver to remove eight 6 mm screws from the bottom of the laptop case.
      • Use a Torx T9 screwdriver to remove the single 6 mm screw.
      Pergunte ao FixBot
      Comentar
    2. HP ProBook 640 G2 Battery Replacement: passo 2, imagem 1 %32
      • Use a plastic opening tool to carefully pry the bottom case.
      • Insert the end of the opening tool into the seam between the bottom and top case and slide it around the perimeter to release the clips.
      • Remove the bottom cover.
      Pergunte ao FixBot
      Comentar
    3. HP ProBook 640 G2 Battery Replacement: passo 3, imagem 1 %32 HP ProBook 640 G2 Battery Replacement: passo 3, imagem 2 %32 HP ProBook 640 G2 Battery Replacement: passo 3, imagem 3 %32
      • Use a JIS J1 screwdriver to remove the seven 6 mm screws securing the battery.
      • Lift the battery from the bottom edge and slide it out of the socket on the motherboard.
      Pergunte ao FixBot
      Comentar
Conclusão
Note - Be sure to dispose of your old battery responsibly! Check out iFixit's Guide on Recycling E-waste.
For optimal performance, calibrate your newly installed battery after completing this guide.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 18
Últimos 30 dias: 57
Ao todo: 375
