Ir para o conteúdo principal
HP ProBook 455 G7 RAM Replacement
O que você precisa
  1. HP ProBook 455 G7 RAM Replacement, Lower Case: passo 1, imagem 1 %32
    • Before beginning, completely power off the laptop and unplug the charger and any peripheries.
    • Flip the laptop over so the lower case is facing up.
    • Use a Phillips #1 screwdriver to remove the seven 8 mm-long screws securing the lower case.
    Pergunte ao FixBot
    Comentar
  2. HP ProBook 455 G7 RAM Replacement: passo 2, imagem 1 %32 HP ProBook 455 G7 RAM Replacement: passo 2, imagem 2 %32 HP ProBook 455 G7 RAM Replacement: passo 2, imagem 3 %32
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry around the entire perimeter until the lower case fully releases.
    • Lift and remove the lower case.
    Pergunte ao FixBot
    Comentar
  3. HP ProBook 455 G7 RAM Replacement, Battery: passo 3, imagem 1 %32 HP ProBook 455 G7 RAM Replacement, Battery: passo 3, imagem 2 %32 HP ProBook 455 G7 RAM Replacement, Battery: passo 3, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the three 4 mm-long screws securing the battery.
    • Carefully lift the battery and remove it from the laptop.
    Pergunte ao FixBot
    Comentar
  4. HP ProBook 455 G7 RAM Replacement, RAM: passo 4, imagem 1 %32
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    Pergunte ao FixBot
    Comentar
  5. HP ProBook 455 G7 RAM Replacement: passo 5, imagem 1 %32
    • The RAM stick should pop up at an angle.
    Pergunte ao FixBot
    Comentar
  6. HP ProBook 455 G7 RAM Replacement: passo 6, imagem 1 %32
    • Carefully pull the module directly out of its socket.
    • Align the notch on the new RAM module with the slot in the connector.
    • Slide the module in at an angle, then press down until it clicks into place.
    • The HP ProBook 455 G7 typically supports DDR4 SO-DIMM RAM up to 32 GB (2 × 16 GB). Make sure both sticks are properly seated before reassembling.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Uma outra pessoa concluiu este guia.
Equipe
UMass Dartmouth, Team 1-6, Botvin Fall 2025 Membro de UMass Dartmouth, Team 1-6, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G6
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 26
Ao todo: 153
