Ir para o conteúdo principal
HP ProBook 455 G7 Fan Replacement
O que você precisa
  1. HP ProBook 455 G7 Fan Replacement, Lower Case: passo 1, imagem 1 %32
    • Before beginning, completely power off the laptop and unplug the charger and any peripheries.
    • Flip the laptop over so the lower case is facing up.
    • Use a Phillips #1 screwdriver to remove the seven 8 mm-long screws securing the lower case.
    Pergunte ao FixBot
    Comentar
  2. HP ProBook 455 G7 Fan Replacement: passo 2, imagem 1 %32 HP ProBook 455 G7 Fan Replacement: passo 2, imagem 2 %32 HP ProBook 455 G7 Fan Replacement: passo 2, imagem 3 %32
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry around the entire perimeter until the lower case fully releases.
    • Lift and remove the lower case.
    Pergunte ao FixBot
    Comentar
  3. HP ProBook 455 G7 Fan Replacement, Battery: passo 3, imagem 1 %32 HP ProBook 455 G7 Fan Replacement, Battery: passo 3, imagem 2 %32 HP ProBook 455 G7 Fan Replacement, Battery: passo 3, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the three 4 mm-long screws securing the battery.
    • Carefully lift the battery and remove it from the laptop.
    Pergunte ao FixBot
    Comentar
  4. HP ProBook 455 G7 Fan Replacement, Fan: passo 4, imagem 1 %32 HP ProBook 455 G7 Fan Replacement, Fan: passo 4, imagem 2 %32
    • Remove the three 4 mm-long Phillips #1 screws securing the fan.
    Pergunte ao FixBot
    Comentar
  5. HP ProBook 455 G7 Fan Replacement: passo 5, imagem 1 %32 HP ProBook 455 G7 Fan Replacement: passo 5, imagem 2 %32
    • Gently unplug the fan power cable from the motherboard connector using tweezers or your fingers.
    • Lift the fan up and out to remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Abeer Zaheer
Membro desde: 10/15/25
427 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-6, Botvin Fall 2025 Membro de UMass Dartmouth, Team 1-6, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G6
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 33
Ao todo: 157
