Introdução
This guide will help you replace the cooling fan in your HP Pavilion x360 14m-ba114dx laptop. The fan is responsible for keeping the laptop cool and dissipating heat that builds up as a result of the electronic components in the laptop. If your laptop is extraordinarily loud, is making strange noises, or is overheating, there may be a problem with your laptop’s cooling fan. Please visit this troubleshooting page for possible solutions to the problem. If none of these solutions work, use this guide to replace the fan.
A prerequisite to this guide is removal of the battery. If you notice once the laptop is open that the battery is swollen, remove it with caution. If swollen, do not charge the battery, keep the battery at a stable room temperature, and dispose of it properly at a recycling center. This page will help you deal with a swollen battery.
Also, make sure that you unplug your device from any external power sources and completely power it off before beginning this replacement.
O que você precisa
Using a #0 Phillips-head screwdriver, remove the three 5 mm screws along the bottom of the back cover.
Using a #0 Phillips-head screwdriver, remove the 6 mm screw at the top of the back cover.
Using the plastic Spudger, remove the ZIF connector connecting the power button board to the motherboard. Remove the connector by popping the cap up on top of the connector and sliding it out of its slot.
Ferramenta utilizada nesse passo:Tweezers$4.99
Use the Blunt Tweezers to disconnect the Wireless Card Antenna Cables. Start with the cable labeled M2, which is connected to Port #2. To disconnect he cable, grab it on both sides with the tweezers and pull up.
Use the Blunt Tweezers to disconnect the Antenna Cable labeled A1, which is connected to Port #1. To disconnect he cable, grab it on both sides with the tweezers and pull up.
Using the Blunt Tweezers, unwind the cables from the track to the right of the speaker. The cables are held in place by two black hooks.
Using the flat end of a plastic Spudger, peel back the tape located on the bottom of the motherboard between the heat sink and the motherboard.
5 outras pessoas executaram este guia.
