Ir para o conteúdo principal
HP Pavilion G6 Screen Replacement
O que você precisa
    1. HP Pavilion G6  Screen Replacement, Remove the battery: passo 1, imagem 1 %32 HP Pavilion G6  Screen Replacement, Remove the battery: passo 1, imagem 2 %32 HP Pavilion G6  Screen Replacement, Remove the battery: passo 1, imagem 3 %32
      • Close the laptop and flip it over.
      • Slide the release pin to pop the battery.
      • Remove the battery completely.
      Pergunte ao FixBot
      Comentar
    2. HP Pavilion G6  Screen Replacement, Remove the screw covers: passo 2, imagem 1 %32 HP Pavilion G6  Screen Replacement, Remove the screw covers: passo 2, imagem 2 %32 HP Pavilion G6  Screen Replacement, Remove the screw covers: passo 2, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Open the laptop and locate the screw covers.
      • Remove the screw covers at the bottom of the screen with tweezers.
      • Keep them somewhere safe as you will need to stick them back after the repair.
      Pergunte ao FixBot
      Comentar
    3. HP Pavilion G6  Screen Replacement, Remove the plastic frame: passo 3, imagem 1 %32 HP Pavilion G6  Screen Replacement, Remove the plastic frame: passo 3, imagem 2 %32 HP Pavilion G6  Screen Replacement, Remove the plastic frame: passo 3, imagem 3 %32
      • Unscrew the exposed 2 x Philips screws and set them aside.
      • Starting from the top, pry up the plastic frame with your fingernails or a pry bar.
      • If you are using a pry bar, it can scratch the screen. Apply gentle pressure until the plastic frame pop out all around the frame. Don't force it!
      • Finally, remove the frame.
      Pergunte ao FixBot
      Comentar
    4. HP Pavilion G6  Screen Replacement, Release the screen from the frame: passo 4, imagem 1 %32 HP Pavilion G6  Screen Replacement, Release the screen from the frame: passo 4, imagem 2 %32 HP Pavilion G6  Screen Replacement, Release the screen from the frame: passo 4, imagem 3 %32
      • Remove the black Philips screw from the top on each side.
      • Remove the bottom screw from the hinge to make an easier access to the screws on the side of the screen.
      • Now that the frame is loose, you can remove the 4 x Philips screws holding the screen in the frame.
      Pergunte ao FixBot
      Comentar
    5. HP Pavilion G6  Screen Replacement, Disconnect the screen connector: passo 5, imagem 1 %32 HP Pavilion G6  Screen Replacement, Disconnect the screen connector: passo 5, imagem 2 %32 HP Pavilion G6  Screen Replacement, Disconnect the screen connector: passo 5, imagem 3 %32
      • Turn the laptop back up and carefully tilt the screen out from the frame and rest it on the keyboard.
      • Don't try to fully remove it yet as it is still attached to the motherboard by the screen cable!
      • Gently lift up the adhesive and disconnect the screen connector. That is the screen released and ready for a change for a new one.
      Pergunte ao FixBot
      Comentar
    6. HP Pavilion G6  Screen Replacement, Check the model number before ordering: passo 6, imagem 1 %32 HP Pavilion G6  Screen Replacement, Check the model number before ordering: passo 6, imagem 2 %32
      • Before ordering a new screen make sure that you order the correct model number that is compatible with your old screen.
      • Check the cable connector to make sure you order the correct screen with the correct number of pins.
      Pergunte ao FixBot
      Comentar
Conclusão
honakrisi
Membro desde: 01/28/20
4.263 Reputação
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 56
Ao todo: 2,218
