Ir para o conteúdo principal
HP Pavilion 17-e146us Screen Replacement
O que você precisa
  1. HP Pavilion 17-e146us Screen Replacement, Screen: passo 1, imagem 1 %32 HP Pavilion 17-e146us Screen Replacement, Screen: passo 1, imagem 2 %32
    • Open the laptop.
    • Remove the two stickers on the lower left and right-hand corner of the laptop screen.
    Pergunte ao FixBot
    Comentar
  2. HP Pavilion 17-e146us Screen Replacement: passo 2, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the two 5 mm screws in the lower left and right-hand corner of the laptop screen.
    Pergunte ao FixBot
    Comentar
  3. HP Pavilion 17-e146us Screen Replacement: passo 3, imagem 1 %32 HP Pavilion 17-e146us Screen Replacement: passo 3, imagem 2 %32
    • Place a spudger or opening tool between the laptop screen and the plastic laptop frame.
    • Apply light pressure to the spudger to separate the plastic laptop frame covering the edges of the laptop screen.
    • These silver pieces cover the laptop hinges and will need to be removed as well.
    Pergunte ao FixBot
    Comentar
  4. HP Pavilion 17-e146us Screen Replacement: passo 4, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the four 4 mm screws in each corner of the laptop screen.
    • This will separate the laptop cover from the laptop screen frame.
    • Hold the laptop cover securely to prevent damage.
    Pergunte ao FixBot
    Comentar
  5. HP Pavilion 17-e146us Screen Replacement: passo 5, imagem 1 %32 HP Pavilion 17-e146us Screen Replacement: passo 5, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the four 3 mm screws on the side of the frame, one in each corner.
    • This will release the laptop screen from the frame.
    • Hold the laptop screen and frame securely to prevent damage to the motherboard attachments.
    Pergunte ao FixBot
    Comentar
  6. HP Pavilion 17-e146us Screen Replacement: passo 6, imagem 1 %32 HP Pavilion 17-e146us Screen Replacement: passo 6, imagem 2 %32
    • Remove laptop screen.
    • While removing the laptop screen, be careful not to destroy the tape connection or break the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 23
Ao todo: 851
