Ir para o conteúdo principal
HP Pavilion 15-eh Battery Replacement
O que você precisa
  1. HP Pavilion 15-eh Battery Replacement, Prepare your laptop for disassembly: passo 1, imagem 1 %32
    • Fully shut down your laptop and unplug all cables.
  2. HP Pavilion 15-eh Battery Replacement, Flip your laptop over: passo 2, imagem 1 %32
    • Flip your laptop over so the rubber feet are facing up.
  3. HP Pavilion 15-eh Battery Replacement, Expose the back cover screws: passo 3, imagem 1 %32 HP Pavilion 15-eh Battery Replacement, Expose the back cover screws: passo 3, imagem 2 %32 HP Pavilion 15-eh Battery Replacement, Expose the back cover screws: passo 3, imagem 3 %32
    • The ends of the rubber feet cover four back cover screws.
    • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
    • Make sure both the foot and its adhesive peel up together, as they need to be lifted up as one piece.
    • Peel up the end of the foot with your fingers just until the hidden screw underneath is exposed—you don't need to fully remove the foot.
  4. HP Pavilion 15-eh Battery Replacement: passo 4, imagem 1 %32 HP Pavilion 15-eh Battery Replacement: passo 4, imagem 2 %32 HP Pavilion 15-eh Battery Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Tesa 61395 Tape
    $5.99
    Comprar
    • Peel up the other ends of the feet to expose the three remaining screws.
    • During reassembly:
    • Press down firmly on the ends of the feet to secure them into their recesses.
    • If the foot adhesive doesn't remain tacky enough to readhere, you can use double-sided tape such as Tesa Tape.
  5. HP Pavilion 15-eh Battery Replacement, Unfasten the back cover: passo 5, imagem 1 %32 HP Pavilion 15-eh Battery Replacement, Unfasten the back cover: passo 5, imagem 2 %32
    • Use a Phillips screwdriver to remove the six screws securing the back cover:
    • Four larger 6.6 mm-long black screws
    • Two smaller 4.8 mm-long silver screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
  6. HP Pavilion 15-eh Battery Replacement, Release the clips: passo 6, imagem 1 %32 HP Pavilion 15-eh Battery Replacement, Release the clips: passo 6, imagem 2 %32
    • Tight plastic clips secure the back cover to the frame. You'll hear and feel the clips release as you work.
    • Insert the flat end of a spudger between the top edge of the back cover and frame, just to the left of the right hinge.
    • Pry up with the spudger to release the clips securing the top right corner of the back cover.
  7. HP Pavilion 15-eh Battery Replacement: passo 7, imagem 1 %32 HP Pavilion 15-eh Battery Replacement: passo 7, imagem 2 %32 HP Pavilion 15-eh Battery Replacement: passo 7, imagem 3 %32
    • Insert the flat end of a spudger between the top right corner of the back cover and frame.
    • Slide the spudger down to the bottom right corner to release the clips on the right edge.
  8. HP Pavilion 15-eh Battery Replacement: passo 8, imagem 1 %32 HP Pavilion 15-eh Battery Replacement: passo 8, imagem 2 %32 HP Pavilion 15-eh Battery Replacement: passo 8, imagem 3 %32
    • Insert the flat end of a spudger between the bottom right corner of the back cover and frame.
    • Slide the spudger to the bottom left corner to release the clips.
  9. HP Pavilion 15-eh Battery Replacement: passo 9, imagem 1 %32 HP Pavilion 15-eh Battery Replacement: passo 9, imagem 2 %32 HP Pavilion 15-eh Battery Replacement: passo 9, imagem 3 %32
    • Insert the flat end of a spudger between the bottom left corner of the back cover and frame.
    • Slide the spudger up to the top left corner to release the clips on the left edge.
  10. HP Pavilion 15-eh Battery Replacement: passo 10, imagem 1 %32 HP Pavilion 15-eh Battery Replacement: passo 10, imagem 2 %32 HP Pavilion 15-eh Battery Replacement: passo 10, imagem 3 %32
    • Insert the flat end of a spudger between the top edge of the back cover and frame, just to the right of the left hinge.
    • Slide the spudger towards the right hinge to release the remaining clips.
  11. HP Pavilion 15-eh Battery Replacement, Remove the back cover: passo 11, imagem 1 %32 HP Pavilion 15-eh Battery Replacement, Remove the back cover: passo 11, imagem 2 %32 HP Pavilion 15-eh Battery Replacement, Remove the back cover: passo 11, imagem 3 %32
    • Remove the back cover.
    • To reinstall the back cover, lay it on the frame and firmly press down around the perimeter to engage all the clips.
  12. HP Pavilion 15-eh Battery Replacement, Unfasten the battery: passo 12, imagem 1 %32 HP Pavilion 15-eh Battery Replacement, Unfasten the battery: passo 12, imagem 2 %32
    • Given the design of the battery connector, the only way to disconnect the battery is to physically remove it.
    • Try not to bend, crease, deform, poke, or puncture the battery with your tool—a damaged battery is a potential fire hazard.
    • Use a Phillips screwdriver to remove the six 3.9 mm-long screws securing the battery.
  13. HP Pavilion 15-eh Battery Replacement, Remove the battery: passo 13, imagem 1 %32 HP Pavilion 15-eh Battery Replacement, Remove the battery: passo 13, imagem 2 %32 HP Pavilion 15-eh Battery Replacement, Remove the battery: passo 13, imagem 3 %32
    • Gently lift the upper edge of the battery to disconnect its socket from the motherboard.
    • Remove the battery.
    • During reassembly, use the alignment posts to position the battery and press down on the socket to secure it.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
Conclusão
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
For optimal performance, calibrate your newly installed battery after completing this guide.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Uma outra pessoa concluiu este guia.
Spencer Day
Membro desde: 09/14/22
55.203 Reputação
Autoria de 408 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.430 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 17
Últimos 30 dias: 94
Duração total: 826
