Ir para o conteúdo principal
HP Pavilion 15-cd040wm Screen Replacement
O que você precisa
  1. HP Pavilion 15-cd040wm Screen Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: passo 1, imagem 1 %32 HP Pavilion 15-cd040wm Screen Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: passo 1, imagem 2 %32
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
    Pergunte ao FixBot
    Comentar
  2. HP Pavilion 15-cd040wm Screen Replacement: passo 2, imagem 1 %32 HP Pavilion 15-cd040wm Screen Replacement: passo 2, imagem 2 %32
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. HP Pavilion 15-cd040wm Screen Replacement: passo 3, imagem 1 %32 HP Pavilion 15-cd040wm Screen Replacement: passo 3, imagem 2 %32 HP Pavilion 15-cd040wm Screen Replacement: passo 3, imagem 3 %32
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
    Pergunte ao FixBot
    Comentar
  4. HP Pavilion 15-cd040wm Screen Replacement, Battery: passo 4, imagem 1 %32 HP Pavilion 15-cd040wm Screen Replacement, Battery: passo 4, imagem 2 %32
    • 2x 5mm Philips screws
    • 2x 3mm Philips screws
    Pergunte ao FixBot
    Comentar
  5. HP Pavilion 15-cd040wm Screen Replacement: passo 5, imagem 1 %32 HP Pavilion 15-cd040wm Screen Replacement: passo 5, imagem 2 %32
    • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
    • Pull out the battery at an angle and lift it out of the laptop.
    Pergunte ao FixBot
    Comentar
  6. HP Pavilion 15-cd040wm Screen Replacement, Screen: passo 6, imagem 1 %32 HP Pavilion 15-cd040wm Screen Replacement, Screen: passo 6, imagem 2 %32 HP Pavilion 15-cd040wm Screen Replacement, Screen: passo 6, imagem 3 %32
    • Remove the four 6.0 mm screws from the hinges using a size Phillips #0 screwdriver.
    • Use the iFixit opening tool to lift both of the hinges.
    Pergunte ao FixBot
    Comentar
  7. HP Pavilion 15-cd040wm Screen Replacement: passo 7, imagem 1 %32 HP Pavilion 15-cd040wm Screen Replacement: passo 7, imagem 2 %32 HP Pavilion 15-cd040wm Screen Replacement: passo 7, imagem 3 %32
    • Using the spudger or opening tool, remove the ribbon that connects to the screen.
    • Gently pull the ribbon out of the port after using the spudger to lift the supporter up.
    • Carefully remove the two antenna wires that connect to the screen as well. Do this by gently pulling them free from their connectors at the wifi card.
    Pergunte ao FixBot
    Comentar
  8. HP Pavilion 15-cd040wm Screen Replacement: passo 8, imagem 1 %32
    • Once these steps are completed, you may lift the display assembly free from the rest of the device.
    Pergunte ao FixBot
    Comentar
Conclusão
Zachary Simao
Membro desde: 03/08/19
423 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 8
Últimos 30 dias: 25
Ao todo: 1,129
