Ir para o conteúdo principal
HP Pavilion 15-cc561st Heat Sink Replacement
O que você precisa
  1. HP Pavilion 15-cc561st Heat Sink Replacement, Bottom Cover: passo 1, imagem 1 %32 HP Pavilion 15-cc561st Heat Sink Replacement, Bottom Cover: passo 1, imagem 2 %32 HP Pavilion 15-cc561st Heat Sink Replacement, Bottom Cover: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Before you begin to remove the bottom cover, shut down the computer. Disconnect all external devices and unplug the AC adapter. Flip the laptop upside down.
    • Use a Phillips #0 screwdriver to remove five screws from the bottom cover:
    • Two 5.6 mm screws
    • Each of these screws are beneath the two rubber feet on the rear side of the laptop (near the display hinges). You do not have to completely remove the rubber feet to remove the screws; simply peel the top of the feet to reveal the screws.
    • Three 5.8 mm screws
    • Throughout this repair, keep track of each screw size and location to avoid damaging your device.
  2. HP Pavilion 15-cc561st Heat Sink Replacement: passo 2, imagem 1 %32 HP Pavilion 15-cc561st Heat Sink Replacement: passo 2, imagem 2 %32
    • Insert an opening tool into the space between the display hinges and the bottom cover.
    • Firmly push the opening tool upwards to separate the bottom cover from these areas.
  3. HP Pavilion 15-cc561st Heat Sink Replacement: passo 3, imagem 1 %32 HP Pavilion 15-cc561st Heat Sink Replacement: passo 3, imagem 2 %32 HP Pavilion 15-cc561st Heat Sink Replacement: passo 3, imagem 3 %32
    • Insert your opening tool and firmly push the tool upwards along the rear edge.
  4. HP Pavilion 15-cc561st Heat Sink Replacement: passo 4, imagem 1 %32 HP Pavilion 15-cc561st Heat Sink Replacement: passo 4, imagem 2 %32 HP Pavilion 15-cc561st Heat Sink Replacement: passo 4, imagem 3 %32
    • Use the opening tool again on the left and right sides.
    • Start prying at the areas closer to the rear of the laptop (near the display hinges) before moving towards areas that are closer to the front of the laptop (away from the display hinges).
    • Pry a little bit on the left side, then pry a little bit on the right side before prying more on the left side again. Working on both sides in this incremental fashion is easier than completely prying one side before starting the other side.
  5. HP Pavilion 15-cc561st Heat Sink Replacement: passo 5, imagem 1 %32
    • Lift the bottom cover upwards to remove it.
  6. HP Pavilion 15-cc561st Heat Sink Replacement, Battery: passo 6, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the five 5.7 mm screws that secure the battery.
  7. HP Pavilion 15-cc561st Heat Sink Replacement: passo 7, imagem 1 %32 HP Pavilion 15-cc561st Heat Sink Replacement: passo 7, imagem 2 %32 HP Pavilion 15-cc561st Heat Sink Replacement: passo 7, imagem 3 %32
    • Pull the battery towards the front edge of the laptop to disconnect it from the 8-pin battery connector.
    • Lift the disconnected battery upwards to remove it.
    • Calibrate a newly-installed battery to help your laptop get an accurate battery percentage reading.
  8. HP Pavilion 15-cc561st Heat Sink Replacement, Fan: passo 8, imagem 1 %32
    • Disconnect the fan cable from the motherboard.
    • Handle the cable by the connector. Avoid pulling on the cables themselves to avoid damaging the cables.
  9. HP Pavilion 15-cc561st Heat Sink Replacement: passo 9, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the three 5.8 mm screws that secure the fan.
  10. HP Pavilion 15-cc561st Heat Sink Replacement: passo 10, imagem 1 %32
    • Lift the fan upwards to remove it.
  11. HP Pavilion 15-cc561st Heat Sink Replacement, Heat Sink: passo 11, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the four 3.0 mm screws that secure the heat sink.
  12. HP Pavilion 15-cc561st Heat Sink Replacement: passo 12, imagem 1 %32 HP Pavilion 15-cc561st Heat Sink Replacement: passo 12, imagem 2 %32 HP Pavilion 15-cc561st Heat Sink Replacement: passo 12, imagem 3 %32
    • Lift the heat sink upwards to remove it.
    • Thermal paste must be thoroughly cleaned from the surfaces of both the heat sink and the processor each time the heat sink is removed. Apply new thermal paste before reinstalling the heat sink.
Conclusão
Nicholas Barger
Membro desde: 09/26/22
181 Reputação
Autoria de 2 guias
Equipe
CSU Los Angeles, Team 6-4, Adachi Fall 2022 Membro de CSU Los Angeles, Team 6-4, Adachi Fall 2022
CSULA-ADACHI-F22S6G4
4 Membros
Autoria de 7 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 23
Ao todo: 472
