Ir para o conteúdo principal
HP G72 Memory Module Replacement
O que você precisa
  1. HP G72 Memory Module Replacement, Memory Module: passo 1, imagem 1 %32 HP G72 Memory Module Replacement, Memory Module: passo 1, imagem 2 %32 HP G72 Memory Module Replacement, Memory Module: passo 1, imagem 3 %32
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer.
    • Turn the computer so that it faces upside down. Position the computer with the front toward you.
    • Slide the battery release latch to release the battery. Pivot the battery to remove it.
    • Loosen the three Phillips M2.5×6.0 captive screws that secure the memory module compartment cover.
    Pergunte ao FixBot
    Comentar
  2. HP G72 Memory Module Replacement: passo 2, imagem 1 %32 HP G72 Memory Module Replacement: passo 2, imagem 2 %32 HP G72 Memory Module Replacement: passo 2, imagem 3 %32
    • Use a plastic opening tool (or equivalent) to lift the back side of the cover. Small tabs hold the cover in place. Firmly pull up on the cover to release the tabs.
    • Remove the cover
    • Spread the retaining tabs on each side of the memory module slot to release the memory module. Remove the module as needed
    Pergunte ao FixBot
    Comentar
Conclusão
oldturkey03
Membro desde: 09/29/10
858.631 Reputação
Autoria de 123 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 43
Ao todo: 2,963
