Ir para o conteúdo principal
HP G72 Hard Drive Replacement
O que você precisa
  1. HP G72 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 HP G72 Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32 HP G72 Hard Drive Replacement, Hard Drive: passo 1, imagem 3 %32
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer.
    • Turn the computer so that it faces upside down. Position the computer with the front toward you.
    • Slide the battery release latch to release the battery. Pivot the battery to remove it.
    Pergunte ao FixBot
    Comentar
  2. HP G72 Hard Drive Replacement: passo 2, imagem 1 %32 HP G72 Hard Drive Replacement: passo 2, imagem 2 %32 HP G72 Hard Drive Replacement: passo 2, imagem 3 %32
    • Loosen the two Phillips 2.5×6.0 captive screws that secure the hard drive cover to the computer.
    • The cover is snapped in by some clips. Use a plastic opening tool on both sides to remove the cover.
    Pergunte ao FixBot
    Comentar
  3. HP G72 Hard Drive Replacement: passo 3, imagem 1 %32 HP G72 Hard Drive Replacement: passo 3, imagem 2 %32 HP G72 Hard Drive Replacement: passo 3, imagem 3 %32
    • Remove the cover
    • Remove the four Phillips M2.5x5.0 screws
    • Disconnect the hard drive cable from the system board.
    Pergunte ao FixBot
    Comentar
  4. HP G72 Hard Drive Replacement: passo 4, imagem 1 %32 HP G72 Hard Drive Replacement: passo 4, imagem 2 %32 HP G72 Hard Drive Replacement: passo 4, imagem 3 %32
    • Remove the hard drive from the hard drive bay
    • Remove the hard drive cable from the drive.
    • Remove the four (two on either side) Phillips M3.0×4.0 screws that secure the hard drive bracket to the hard drive
    Pergunte ao FixBot
    Comentar
Conclusão
10 outras pessoas executaram este guia.
oldturkey03
Membro desde: 09/29/10
856.990 Reputação
Autoria de 123 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 44
Ao todo: 8,102
