Introdução
Use this guide to replace the battery in your HP EliteBook x360 830 G6.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
O que você precisa
Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
Pry upward to release the retaining clips.
Repeat this process for the opposite corner.
Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
Pry up to release the additional retaining clips.
Grab the cover by the corners next to the hinges.
Swing the cover open and away from you.
Lift and remove the back cover from the laptop body.
Use the point of a spudger to push the sides of the battery connector out of its socket.
Push on alternate sides to "walk" the connector out.
Use your Phillips screwdriver to remove the five 4.2 mm-long screws securing the battery.
Pull the battery out from the retaining tabs at the front of the chassis.
Remove the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
