Ir para o conteúdo principal
HP Chromebook CB2L Battery Replacement
O que você precisa
  1. HP Chromebook CB2L Battery Replacement, Battery: passo 1, imagem 1 %32 HP Chromebook CB2L Battery Replacement, Battery: passo 1, imagem 2 %32
    • First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
    • Next, using the plastic opening tool remove the blue panel.
    Pergunte ao FixBot
    Comentar
  2. HP Chromebook CB2L Battery Replacement: passo 2, imagem 1 %32 HP Chromebook CB2L Battery Replacement: passo 2, imagem 2 %32 HP Chromebook CB2L Battery Replacement: passo 2, imagem 3 %32
    • Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
    • Gently pry off the white back panel using the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  3. HP Chromebook CB2L Battery Replacement: passo 3, imagem 1 %32
    • Disconnect the battery input to the motherboard using the plastic opening tool
    Pergunte ao FixBot
    Comentar
  4. HP Chromebook CB2L Battery Replacement: passo 4, imagem 1 %32
    • Unscrew the four 1.2mm screws using the Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. HP Chromebook CB2L Battery Replacement: passo 5, imagem 1 %32
    • Using the plastic opening tool remove the battery from the Chromebook.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S2-G6, Lacy Spring 2017 Membro de USF Tampa, Team S2-G6, Lacy Spring 2017
USFT-LACY-S17S2G6
3 Membros
Autoria de 4 guias
2Comentários do guia
the step about gently prying the underside of the laptop off made me snap off two screws under the thin blue rubber strip ! i see the holes they went in in the pictures in this guide. i understand that strip was glued on and it doesn't seem necessary to put those back (since i can't unglue the strip to put those screws back in) but.. yeah. it was unexpected and i thought i'd done something wrong.
katie - Responder Compartilhar
Dont forget there are two screws underneath the small blue strip.
Roderick Wells - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 38
Ao todo: 1,789
