Ir para o conteúdo principal
HP 15-ay078nr Battery Replacement
  1. HP 15-ay078nr Battery Replacement, Battery: passo 1, imagem 1 %32
    • Orient the laptop so that the underside is facing up.
    • Rotate the device so that the CD slot is in the upper left corner.
  2. HP 15-ay078nr Battery Replacement: passo 2, imagem 1 %32 HP 15-ay078nr Battery Replacement: passo 2, imagem 2 %32
    • Put your fingers on the battery latch.
  3. HP 15-ay078nr Battery Replacement: passo 3, imagem 1 %32 HP 15-ay078nr Battery Replacement: passo 3, imagem 2 %32
    • Using your fingers, push each battery latch simultaneously towards the middle.
    • This releases the battery.
    • Remove the battery from the laptop.
Conclusão
After installing the replacement battery, connect the device to a power source. The battery will not have a prior charge.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Cameron Duffy
Membro desde: 10/25/21
327 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 3-1, Sinclaire Fall 2021 Membro de UMass Dartmouth, Team 3-1, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G1
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 188
