Ir para o conteúdo principal
HP 14-dq5043cl Wi-Fi Module Replacement
O que você precisa
    1. HP 14-dq5043cl Wi-Fi Module Replacement, Lower Case: passo 1, imagem 1 %32 HP 14-dq5043cl Wi-Fi Module Replacement, Lower Case: passo 1, imagem 2 %32
      • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
      • Remove the two rubber feet on the lower case.
      • If you intend to reuse the rubber feet: Use a hairdryer or iOpener to lightly heat the feet to loosen the adhesive that secures them prior to removal. Take care not to stretch out the rubber.
      Pergunte ao FixBot
      Comentar
    2. HP 14-dq5043cl Wi-Fi Module Replacement: passo 2, imagem 1 %32
      • Remove the six M2XL6 Phillips screws that secure the lower case.
      Pergunte ao FixBot
      Comentar
    3. HP 14-dq5043cl Wi-Fi Module Replacement: passo 3, imagem 1 %32 HP 14-dq5043cl Wi-Fi Module Replacement: passo 3, imagem 2 %32 HP 14-dq5043cl Wi-Fi Module Replacement: passo 3, imagem 3 %32
      • Insert a nylon spudger into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Remove the lower case.
      Pergunte ao FixBot
      Comentar
    1. HP 14-dq5043cl Wi-Fi Module Replacement, Wi-Fi Module: passo 4, imagem 1 %32 HP 14-dq5043cl Wi-Fi Module Replacement, Wi-Fi Module: passo 4, imagem 2 %32
      • Remove the single M2x6.5 screw that secures the Wi-Fi module.
      Pergunte ao FixBot
      Comentar
    2. HP 14-dq5043cl Wi-Fi Module Replacement: passo 5, imagem 1 %32
      • Use the pointed end of a spudger to lift and disconnect the two Wi-Fi module coaxial connectors.
      Pergunte ao FixBot
      Comentar
    3. HP 14-dq5043cl Wi-Fi Module Replacement: passo 6, imagem 1 %32 HP 14-dq5043cl Wi-Fi Module Replacement: passo 6, imagem 2 %32
      • Pull the Wi-Fi module directly out of its socket to remove it.
      Pergunte ao FixBot
      Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Tristan Virgo
Membro desde: 02/19/25
564 Reputação
Autoria de 5 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 19
Ao todo: 220
