Ir para o conteúdo principal
Garmin inReach Explorer Plus LCD Screen Replacement
O que você precisa
  1. Garmin inReach Explorer Plus LCD Screen Replacement, Battery: passo 1, imagem 1 %32
    • Using the TR6 Torx Security screwdriver, remove six 10 mm screws from the back cover of the device.
    Pergunte ao FixBot
    Comentar
  2. Garmin inReach Explorer Plus LCD Screen Replacement: passo 2, imagem 1 %32
    • Remove the back cover.
    Pergunte ao FixBot
    Comentar
  3. Garmin inReach Explorer Plus LCD Screen Replacement: passo 3, imagem 1 %32 Garmin inReach Explorer Plus LCD Screen Replacement: passo 3, imagem 2 %32
    • Gently grasp the battery wire and disconnect it from the device.
    • Remove the battery from the device.
    Pergunte ao FixBot
    Comentar
  4. Garmin inReach Explorer Plus LCD Screen Replacement, Motherboard: passo 4, imagem 1 %32 Garmin inReach Explorer Plus LCD Screen Replacement, Motherboard: passo 4, imagem 2 %32
    • Using the T5 Torx screwdriver, remove the six 6 mm screws from the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Garmin inReach Explorer Plus LCD Screen Replacement: passo 5, imagem 1 %32 Garmin inReach Explorer Plus LCD Screen Replacement: passo 5, imagem 2 %32
    • Disconnect the LCD screen from the motherboard by lifting on the flap with the nylon spudger.
    • The metal spudger should only be used for serious prying power. If used incorrectly, the metal spudger may damage the components of a device.
    Pergunte ao FixBot
    Comentar
  6. Garmin inReach Explorer Plus LCD Screen Replacement: passo 6, imagem 1 %32 Garmin inReach Explorer Plus LCD Screen Replacement: passo 6, imagem 2 %32
    • Disconnect the antenna from the motherboard by lifting the wire with a nylon spudger.
    Pergunte ao FixBot
    Comentar
  7. Garmin inReach Explorer Plus LCD Screen Replacement: passo 7, imagem 1 %32 Garmin inReach Explorer Plus LCD Screen Replacement: passo 7, imagem 2 %32 Garmin inReach Explorer Plus LCD Screen Replacement: passo 7, imagem 3 %32
    • Gently lift the motherboard up and out of the device.
    Pergunte ao FixBot
    Comentar
  8. Garmin inReach Explorer Plus LCD Screen Replacement, LCD Screen: passo 8, imagem 1 %32 Garmin inReach Explorer Plus LCD Screen Replacement, LCD Screen: passo 8, imagem 2 %32
    • Using the T5 Torx screwdriver, remove the two 6 mm screws from the LCD screen.
    Pergunte ao FixBot
    Comentar
  9. Garmin inReach Explorer Plus LCD Screen Replacement: passo 9, imagem 1 %32 Garmin inReach Explorer Plus LCD Screen Replacement: passo 9, imagem 2 %32 Garmin inReach Explorer Plus LCD Screen Replacement: passo 9, imagem 3 %32
    • Use a nylon spudger to separate the LCD screen from the main body and remove the LCD screen.
    Pergunte ao FixBot
    Comentar
Conclusão
Sean Kelley
Membro desde: 09/28/21
387 Reputação
Autoria de 4 guias
Equipe
Clemson, Team 5-4, Hunter Fall 2021 Membro de Clemson, Team 5-4, Hunter Fall 2021
CLEM-HUNTER-F21S5G4
4 Membros
Autoria de 5 guias
3Comentários do guia
Where do I purchase the replacement LCD screen?
Tyler Lawrence - Responder Compartilhar
Ditto - where can we get a screen??
Ben Wallbank - Responder Compartilhar
Yes where can LCD SCREEN BE BOUGHT
Roy Shields - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 51
Ao todo: 1,715
